Question about Tablets & eReaders
I have put a sim card in the tablet and can't get it out as it looks like its too small
    Top Expert:
  • Tablets & eR... Master
  • 8,204 Answers
Try using a very small pin or paper clip but make sure its all turned off.
Posted on Dec 13, 2016
Sim card for Samsung Galaxy tablet 4?
A SIM card is for 4G LTE internet service, so if you have a Samsung Tab 4 ensure it is 4G capable before trying to insert a SIM card. If you try to insert a SIM card into a SD Card slot you may damage the card reader.
That being said, I believe it is located on the right side of the tablet. Sometimes the SD Card slot and the Sim card slot are right next to each other. Once you open the cover that reveals the slots there should be small icons for the SD Card and the Sim card. Normally, the SIM card slot will have a little notch on the icon. Attached are guides with pictures.
SIM card Samsung Galaxy Tab 4
Oct 22, 2016 | Samsung Tablets & eReaders
How do i put sim card in sprint tablet powered by android
Depends on the model of tablet. Some require you use a paper clip to release the Sim card door. Check the owners manual or sprints website for model specific info
Oct 13, 2016 | Tablets & eReaders
Were do i put my sim card in a rca tablet
There should be a slot along the side, you may need to remove a small rubber cap they sometimes put on top of the sim slots. make sure you insert the card the right way in, you should feel a click if card is seated properly then put the rubber cap back on.
Oct 02, 2016 | Tablets & eReaders
SIM card is stuck in my tablet. How do I remove it?
Even when the SIM card is fully inserted you can usually see a small section which sticks out of the metal housing. You should be able to gently (but firmly) ease the SIM out using a large sewing needle or something similar.
Sep 11, 2015 | Tagital 7" Dual Core Android 4.2 Bluetooth...
How i can put simcard show vedeo
1) you state the problem is with an Apple iPad 32gb Wifi Tablet. You will be unable to put a sim card in as this is not the 3G / 4G version.
2) Refer to the original product documentation.
3) Have you searched the manufacture website? There are online user guides on
4) Use a small needle and press it in to the hole on the sim card slot. remove, insert your simcard and insert in to the ipad.
Jun 08, 2014 | Apple iPad 32 GB WiFi Tablet PC
SIM card replaceed and device blocked
Take out the card, there is a small switch on the side with a (Lock>) tittle above it. Put it on the other direction.
Apr 23, 2014 | Tablets & eReaders
Were to put sim card on karno tablet
Sim card? I don't believe it supports a Sim card. It does support a SD card for memory. If that's what you meant then it would be on the side where you can plug in your headphones. Next to the slot it should be labled.
Feb 01, 2014 | Tablets & eReaders
How to put in sim card
Assuming you mean the 2013 version but I'll try both,
so for the 2013 version
  1. Turn your tablet off and place it on a flat surface with the screen facing up.
  2. Tilt the right side slightly up to find the SIM card tray near the bottom right and the small hole in the tray door.
  3. Insert a paperclip into the hole in the tray door, and push firmly but gently, the tray should pop out.
  4. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271601_en_v0Remove the tray and place the micro SIM card inside it, the angle corner fits with the angled indent
  5. Push the tray it gently back into the tablet.
  6. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271604_en_v0
Activate SIM card
  1. Open the Settings app snp_2918920_en_v1 and turn off Wi-Fi after completing the set-up instructions. Once Wi-Fi is off, you'll see a notification at the top of your screen.
  2. Swipe down the notification shade and touch the notification.
  3. Follow the activation instructions provided by your carrier.
For the Nexus 7 (2012) 3G use the same process noting that the tray slot and pinhole is on the left side of the device when its facing up.
*Note* : Only the Nexus 7 (2013) LTE & Nexus 7 (2012) 3G can accept a SIM card. Wi-Fi versions of the tablet can't.
Dec 10, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
My sim card not installed
It may be a case of wrong cutting of the micro sim. Since the iPad uses a microsim, you haveto make sure that the sim card is cut perfectly. Do not use a pair of scissors, you have to cut it specifically using a micro sim cutter. Or you can check if the placement of the sim card is correct. Sometimes, the card seems to get loose thus making it unreadable by the iPad.
Mar 07, 2011 | Apple iPad 64 GB 3G Tablet PC
Tablets & eReaders Logo
27 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
