Question about Viking Kitchen Ranges
Can you please tell me the steps to replace the thermostat on the small oven of my Viking rande. Model: VDSC4856QSS. The thermostat part number is: PJ030003. Thankyou, John Weidert
5 Suggested Answers
brnspncr
  • 67 Answers
SOURCE: Viking professional Range Thermostat problem
Try www.retrevo.com/s/Viking-Range-VGIC305-4B-Ranges-review-manual/id/6768ag911/t/1-2/ . . .Good luck
Posted on Jul 30, 2009
  • 30 Answers
SOURCE: replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
Posted on Jul 02, 2010
  • 2069 Answers
SOURCE: viking model vdsc4874gss small oven
probably, power failure occurred, the electric ignitors will not work. The range surface burners can still be used, but only when the burners are lit manually with a match. The griddle cannot be used at all.
I recommend you have electrician check power circuit breaker, wiring and fuses.
Posted on Oct 19, 2010
allbrands
  • 600 Answers
SOURCE: What is the part number
I searched all over and i am not finding your gasket here is a link that will help you and get you the correct part.
http://www.nationalpartscenter.com/viking/
Sorry i couldnt find the exact part number.....
Posted on Jul 02, 2011
How do I replace an oven thermostat on a Viking D3 stand alone range?
Hello Tod,
I can make a long story but can do it with a very short story, as someone else has ansered this question on another site already very clear. You can find it on the link I send you.
I wish you succes with it.
Kind regards, Dik
Viking VDSC305 Oven Thermostat Replacement
Mar 18, 2018 | Viking Kitchen Ranges
Part numbers for door gaskets Viking double oven ved0530ss
Go to searspartsdirect.com with your model number. You'll find parts lists and diagrams there
Dec 01, 2017 | Viking Ovens
How do I replace a ribbon element in a Viking oven.
Hi, I would like to help you but I need more information. What is the model number and the first 6 numbers including the letter of the serial number please. Also I need to know what ribbon you are referring to as in the location of which component you are referring too wold greatly assist me to assist you. General questions get general answers, because I can't see it I need you to elaborate more information please. Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 27, 2014 | Viking Ovens
I have a Viking double wall oven model DEDO130. I have terrible baking results in the upper and lower. Mostly burning the tops (pizza, biscuits, etc) while the centers aren't done. A tech from the...
Home > Cooking Parts > Wall Oven Parts > Control Panel Area > Oven Thermostats >
G50012998 DESO SERIES T/STAT KIT Viking Electronic Part. ALL SALES ARE FINAL.
Viking Thermostat Replacement Kit
btn_emailafriend.gif pbox_border_left_top.gif clear1x1.gif pbox_border_right_top.gif clear1x1.gif G50012998 DESO SERIES T/STAT KIT Viking
List Price: $189.14
Our Price: $133.83
You save $55.31!
Return Policy Electronic Part. ALL SALES ARE FINAL.
Availability:: Usually Ships in 1 to 2 Business Days Subject to Stock Availability - Call to be sure.
Product Code: G50012998
The part is not that hard to replace. but it is expensive. In my opinion it should correct your problem since you have that much difference.
clear1x1.gif pbox_border_left_bottom.gif clear1x1.gif pbox_border_right_bottom.gif
Jun 08, 2011 | Ovens
Sears Canada bought Eatons Canada back in 2002. Eatons sold Viking products. I bought I Sears Viking over the range Viking microwave built in 2002. Nomeclature # 851.8250800 Model # 82508 Ser#...
This is a Sanyo microwave. the "851" number is the manufacturer number or "source" number. I can't tell you any more about that particular model.
I would remove the circuit board (control panel) and check for damaged/burnt copper print. Where the copper is burnt, you can solder on jumper wires to complete the circuit.
Mar 01, 2011 | Kenmore 80492 / 80494 / 80499 1000 Watts...
Viking Thermostat bad - Feels like Little House on Prairie
It does not sound like the guy is trying to rip you off. Most mechanical thermostats are adjustable by a center screw in the oven control knob stem behind the knob. The problem is when an oven is off by more than 30 degrees they become almost impossible to calibrate correctly and it is better to replace it. There would not be any danger in just using the thermometers and just living with the problem. It would be a very expensive fix for a Viking and if you can live with it then you are better off. The parts alone will probably be over $300 and then there is the labor charges. The thermostat assembly also includes the tempature probes so it requires major range dis-assembly to replace it. Sometimes the oven control knob will have an adjustment screw on the knob istelf(back of knob) to adjust the position of the dial ring to match the correct oven tempature. This can allow you to change the position of the knob to match the actual tempature of the oven. They usually will only go 30 degrees one way or the other though. So my advice is that if you can live with it and are able to still cook properly then put off fixing it. If you find that over time the cooking tempatures start increasing then you might have no choice but to have the thermostat assembly replaced.
Apr 11, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
Problem with Viking stove griddle knob shaft
Abalos, we will be happy to assist you with your parts for the Viking griddle knob.
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Mar 08, 2010 | Viking VGIC485-6G Gas Kitchen Range
Replacing PB010036 Bake / Broil Thermostat Viking
Dec 12, 2009 | Viking VGIC485-6G Gas Kitchen Range
Wehre is model number located on viking oven?
It is usually on the stove at the bottom of the oven door. you might have to remove it to read it properly
Sep 18, 2009 | Viking Ovens
Viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Sep 20, 2007 | Viking DEDO205 Stainless Steel Electric...
Kitchen Ranges Logo
81 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
