Question about Cell Phones
It wont charge.It will turn on and "android" pops up on the screen,but it freezes.When I try to charge it,it shows a green battery on the screen for 3 sec,then the battery goes red and it shuts off.
    Top Expert:
  • Cell Phones Master
  • 77,499 Answers
I would start by replacing the battery, if that doesn't correct the issue try a factory reset.
Posted on Dec 13, 2016
My tablet wont charge or turn on please help
Check its charger. If the charger is faulty, it won't charge the battery. If it is found OK, replace the battery. It is bad.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 17, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
Htc amaze 4g wont turn on after charged
Try leaving the battery in with it charging all night, if the phone won't turn on after that, you'll need to exchange it.
Jan 16, 2013 | HTC Amaze 4G Android Smartphone
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
My g1 wont pass the android screen it turns off automatically and its been charging for 6 hours and it only shows me the red led please help!! Thanks
Try swapping out the battery with a fully charged battery. However, this is most likely a hardware issue with the battery or the phone itself. Try switching the battery first, but if it doesn't work, it will have to be serviced by a technician.
Jan 16, 2011 | HTC G1 Smartphone
My sidekick 3 wont go past BATTERY LOW! PLEASE ALLOW DEVICE TO ..
turn off your phone. then remove the battery for 5 minutes. also make sure your charger is not plugged in. then put the battery pack into the phone. it should clear up. also you might have over charged the battery. another solution is to buy a new battery pack and if that does not work your phone is acting up on battery basis
Jan 20, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Battery shows fully charged, stays on for 3 minutes and freezes.
I've had this happen. Try a soft reset, if that doesn't fix it - try a hard reset. If it still does this, you will need to replace the battery. It may either be a problem with the battery itself or the power regulation circuit that is built into the battery. Either way, replace the battery and it should fix it. Word of warning though, some aftermarket chargers actually reverse-charge the battery - I had a USB charge/data cradle that did this and I still have short-lived battery life on my new E2 battery if I use that cradle. I just stopped using it because it kills my E2.
Jan 12, 2009 | HTC Touch P3450 Smartphone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
