Question about Nordic Track Exercise & Fitness
My nordic track start up at a high speed the n quits. the system show s it is still running
    Novelist:
  • 145 Answers
Your lower control board has a shorted part, these boards are repaired by Jatinah Electronics which can be found with a google search. This problem will require a new or repaired control board. Good Luck!
Posted on Dec 13, 2016
Nordic Track NordicTrack Reflex 4500 Pro Treadmill - My belt speed is running about 60% of the speed displayed. What is causing that? Is there a reset feature?
The treadmill is set for kilometers, not miles.
With the stop button pressed, insert the safety key/magnet. This will display miles (or Kms) and hours of use.
There will also be a "M" for metric or "E" for english, or miles. Use the speed up/down buttons to adjust to "E".
Oct 01, 2017 | Nordic Track Exercise & Fitness
Speed not steady, and not reading on console. Incline not working or reading.
Proform Treadmill Incline Problem Fixed How to reset re calibrate your treadmill
Please see this video for to help you to fix it in incline and calibration incline motor
Blessing
cuadra2016@yandex.com
cell+whatsApp: +50588611441
Jan 21, 2018 | Nordic Track Exercise & Fitness
Nordic track 1000 works only on speeds 1 and 7
adjust the speed sensor, see the diagram attached. clean it and test it for open or faulty. Tight the connector very well.RUN the software calibration for easy diagnose, and fix it. God bless you3_22_2013_4_23_05_pm.gif3_22_2013_4_23_19_pm.gif
Mar 22, 2013 | Nordic Track NordicTrack Treadmill, A2550
I have a Nordic Track Viewpoint 3000, the display quit working although the incline and speed seem to be working just fine. Anything I could try to fix?
Dear Sir:
Please see the attached diagram for adjusting the reed switch, clean very well, and tigh the connector wires.
sincerely. God bless you
Apr 21, 2012 | Nordic Track Exercise & Fitness
I hav an a2105 nordic track.. it powers up just fine but when i start the track it starts and shuts down.. and then powers itself back up all over again.. i disconnected the drive belt from the motor to...
hi,
You have to check the Driver circuit board for the motor. There is motor control IGBT Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will try to run without setting any value or witout pressing the start button. You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i ahve added the picture of IGBT for your refference
ok
Aug 14, 2011 | Nordic Track NordicTrack Treadmill, A2550
How do you start the Nordic Track C2205? I have no book.
place the safety key in/on and hit start, select the speed desired and walk or run til your hearts content.
Jul 25, 2010 | Nordic Track 1dzn (12)treadmill Keys For...
My Nordic Track treadmill has has 10 speeds (1mph
You should have a speed arrow up & down, this increases and decreases the speed in .1 mph. Try this control and see how the unit re-acts if the speed does not adjust in .1 mph increments or it stay the same either way it sounds like an upper board issue. Go to iconfitness.com go to customer service the replacement parts put you M# and will give part# and pricing.
RULE OF THUMB: IF REPAIR IS MORE THAN THE THE PURCHASE PRICE OF UNIT DOE NOT REPAIR
Feb 27, 2010 | Nordic Track NordicTrack Treadmill, A2550
Powers on but won't run
nordic track c 2000 starts takes off at high speed and then belts starts. board is still lit up and going as if your walking on it
Dec 27, 2009 | Exercise & Fitness
Replaced the motor controls
Is there a sheet of paper under the motor hood? It has the procedures for this calibration of the motor speed. Caution ! You should use a plastic screwdriver to make adjustment to the speed control on the motor controller. It is high voltage
Mar 01, 2009 | Nordic Track Nordictrack Apex 4100i...
Exercise & Fitness Logo
52 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
