Question about Sewing Machines
How do I adjust the thread tension and bobbin tension on a Huskystar 207?
    Top Expert:
  • Sewing Machines Master
  • 48,339 Answers
Thread tension is by a knob on the face of the machine
if you find by adjusting that , nothing is happening , check the way the thread has been put in as it can get behind the pressure plates and jam on the bolt or not be between the pressure plates and just running free
bobbin tension is by the small screw that holds the flat spring under which you pull the thread after fitting in the bobbin back in the carrier
( seldom need to adjust bobbin thread tension)
Posted on Dec 13, 2016
The thread gets caught up in bobbin area
This mess is commonly referred to as a bird's nest or 'birdnesting' and it's usually caused by incorrect top tension and that's often caused by the top thread not in the correct path. (For me, I occasionally forget to thread through the take-up lever.) A damaged needle can also cause birdnesting.
Aug 02, 2014 | Husqvarna Huskystar 207 Sewing Machine
My needle wont sew on my husky star 207?
change the needle--make sure it's the right needle for the fabric
being sewed
rethread the machine top using every thread guide
check to make sure the bobbin is not over wound, make sure the
bobbin is not warped, & that the bobbin is inserted correctly into the
make sure the thread has not come off the thread take up lever
it's also possible that the machine is out of time
Jul 14, 2012 | Husqvarna Huskystar 207 Sewing Machine
I can not get my bobbin thread to sew but my top thread does on my Huskystar 207 sewing machine
have you checked to may sure the bobbin is turned the right way & inserted
in the bobbin case the right way?
try changing the needle --flat side goes to the back of the machine
Apr 05, 2012 | Sewing Machines
Bobbin thread jams
try changing the needle--flat side goes to the back of the machine
check the thread take up lever & see if the thread is still on it
it's also possible that the machine is out of time & needs to serviced
Feb 19, 2012 | Husqvarna Huskystar 207 Sewing Machine
Husqvarna Huskystar 207 Sewing Machine not stitching. It won't pull the bobin thread up to sew.
Be sure not to use Singer Needles. They are longer than standard needles. Don't know if this helps, but I did this once on my Huskystar 207 and that is what happened. It also damaged the bobbin thread.
Sep 18, 2011 | Husqvarna Huskystar 207 Sewing Machine
I was making a quilt. The thread snarls and throws loops on the bottom. I think it is the tension. How do I fix it?
The pressure foot has to be lowered to apply tension to the top thread. With pressure foot down, try grasping the thread just above the needle and gently pull downwards to check if there is tension on it. Also try re-threading the top thread from the start with pressure foot raised so thread enters the tension mechanism properly.
Hope this is the solution to get you back to your quilting ... <Ray>
Nov 12, 2010 | Husqvarna Huskystar 207 Sewing Machine
Huskystar 224 top tension will not adjust. Last time I used this machine was a week ago, everything was perfect. Yesterday I started a project, and from the get-go there were big loops on the bottom of...
Have you tried to re-thread the machine? Check to see if the thread is in the take-up lever. There also might be a piece of thread or lint caught between the top tension disks.
Feb 23, 2010 | Sewing Machines
My 5 year old Huskystar 216 sewing machine is
Sounds like the hook/needle timing. To check do the following:
With the power off!!
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding in the right direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to get a good stitch, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website -
Good luck.
Sep 26, 2009 | Husqvarna Sewing Machines
Sewing Machines Logo
62 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
