Question about Tablets & eReaders
Can i use a regular phine charger to charge up my trio tablet
    Top Expert:
  • Tablets & eR... Master
  • 8,302 Answers
I think it best if you get the right charger for it to be on the safe side.
Posted on Dec 13, 2016
Trio Quad Core Tablet will not charge
Either the charger or the battery is faulty, from the sound of your fault description. If the tablet will turn on and run normally when the charger is plugged in, then the problem most likely lies with the battery. If it will not run even when the charger is on, then the charger is most likely the cause of the fault. If your tablet is still under warranty, either problem should be repaired free
Jan 01, 2015 | I-INC UniK Trio AXS 3G with Wifi 7.85"...
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
Oct 18, 2014 | Trio Mach Speed Stealth G2 Tablet - Teal...
Where can I buy a charger for my trio stealth g2 tablet?
I was able to use my cell phone charger when my Trio Stealth Tablet charger stopped working. I would suggest first trying to use a basic cell phone charger before going out and spending lots of money on a charger "specifically" for a tablet.
Jul 11, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Why my trio stealth g2 wont turn on
If it isn't charged it will not turn on.
Make sure the charger is working. Use an AC/USB charger.
Other than that it's broken.
Use the extended warranty you purchased when you bought the tablet.
May 03, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Trio stealth G2-9 battery life will not charge
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
Mar 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Trio tablet wont turn on
sounds like the hard drive is froze up
Mar 08, 2014 | Mach Speed Speed Tablet Trio Stealth G2 7"...
My trio wont work!
try your charger with some other device
if its working then there is a problem with your charging ic
or processor
go to othorize service centre
Feb 01, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
Charge trio g2
Hi Jennifer,
Battery error or charger error.try with new charger or usb cable.
if you have warranty you have no problem and go for warranty.
regards.
nuwan
Jan 10, 2014 | Mach Speed Trio Tablets & eReaders
Trio stealth charging issues
The internal battery may be unable to recharge.
Jan 29, 2018 | Mach Speed Trio Stealth G2 Tablet -...
My trio stealth g2 7" tablet wont turn on
Check for a bad battery, charger in that order.
Each can be gotten inexpensively on ebay. eBayeBay
Sep 04, 2017 | Trio Stealth G2 7 inch Tablet with 8GB...
Tablets & eReaders Logo
24 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
