Question about Hardware & Accessories
I have a berkel 350D vacuum packing machine. Just installed the nitrogen flushing component, it is working. packed some ground beef turned brown in 12 hours. I think I need to have settings info
  • 7 Answers
SOURCE: Hi,I reinstalled OS XP Home and did service pack
First... you need to check if you have instaled SP2, on Start/Control Panel/Add or Remove programs; here select "Show updates"..
If you don't have SP2 installed, here you have the link : http://www.microsoft.com/downloads/details.aspx?FamilyID=049C9DBE-3B8E-4F30-8245-9E368D3CDB5A&displaylang=en .
Download and  install.
Posted on Mar 13, 2009
  • 384 Answers
SOURCE: can you hook more than one set of wires to the pack
It's low voltage I would try another set of light wires...no harm in trying.
Posted on Jul 01, 2009
dnewcombe1
  • 1564 Answers
SOURCE: 1-4 misfire
I'd say you need to replace the 1-4 coil pack. Any changes to the working of the pack have to be tested after the primary source with much more elaborate equipment. The coil pack is easy to replace and will save time and money for testing. Thanks, Dana
Posted on Oct 04, 2009
  • 26 Answers
SOURCE: My subzero Refrigerator Model #-550 is not cooling properly
return it right away
Posted on Jun 12, 2010
  • 760 Answers
SOURCE: I currently have a 600 watt power pack w/timer on
20A circuit x 80% service factor =16amps continuous. 16amps x 120V = 1920 wats. Your total would be only 900 watts. I have assumed that since you have a 20A ground fault breaker that you have #12 ga copper conductors. If you had a considerable distance the 16 amps continuous would drop due to voltage drop and so the total wattage would also, but you're way below these levels.
Posted on Jul 04, 2010
Were to find replacement battery pack
I would suspect that they would only be available thru DIRT DEVIL
Jan 03, 2016 | Dirt Devil BD10165 Gator Bagless Hand Held...
How does one open the battery case?
Hi Russell, it's Jack at Dyson.
The battery pack for our cordless vacuums is manufactured as a sealed assembly, and is not designed to be opened or dismantled - attempting to do so could cause damage. Additionally as the battery pack is supplied to us as a complete assembly, we do not have individual internal components available to order.
We would strongly encourage to you contact us directly so we can take some further details about the issue - talking you through some simple diagnostic checks should help us confirm if the fault lies with the battery pack, charger assembly or the control software in the main body of your Dyson cordless vacuum.
When you have your machine easily to hand, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Mar 18, 2015 | Dyson DC39 Animal Vacuum
When cleaning the cyclone head can this be flushed with water?
Hi Len, it's Jack at Dyson.
The cyclone pack on your DC14 should never be washed, flushed with water or submerged. Any residual water left within the assembly could cause permanent damage to your vacuum not covered under warranty. It could also contribute to an unpleasant odour from your machine in use.
To clean the clear bin and shroud, you can remove the clear bin from the cyclone pack using the catch on the rear of the cyclone pack, as shown below. A soft brush or dry cloth can then be used to remove any clinging fluff or debris from the shroud. Gently tapping the cyclone pack will also help remove any clinging dust particles.
You can also rinse or wipe the inside of the clear bin with a damp cloth to remove any dust particles, but make sure it's completely dry before reassembling.
I hope this helps, but if you'd like any further guidance on maintaining your vacuum, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 11, 2014 | Dyson DC14 FS Telescope Full Kit HEPA...
My transformer turns on for a few seconds and then turns off and it shows E on the display
Troubleshoot:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
If this is the digital type timer, the timer is defective.
But new one.
Read installation tips on link for longer lasting power pack
Install surge protector
Gene
Water Heater Timers Save Money
Nov 04, 2013 | Malibu ML600TW - Low Voltage Power Pack -...
Unit is connected but wont turn on lights, socket is live and has power
Power packs don't have repair parts.
Check that bulbs are not all burned out ... if a few bulbs burn out, then power pack can burn out the rest and power pack also damaged.
People have written fixya reporting they took apart power pack, but nobody reports fixing a power pack once it has gone bad.
"Harry" wrote with a work-around if you can get manual override to turn on lights.
He bought cheap plug-in timer and plugged power pack into cheap timer.
Harry also said his power pack has 5 year warranty, and he was negotiating with Malibulights.com.
Best I found are tips for next power pack that might save money:
The reason I add tips now, is some fella wrote fixya.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
a) Match wattage of bulbs with wattage of power pack
Lets say you have fifteen 20 watt bulbs = 300 watts, so install 300Watt power pack
b) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
c) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
d) When working on bulbs, unplug power pack or power pack may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 17, 2011 | Malibu Intermatic Inc. ML300RTW 300-Watt...
The timer feature of my Malibu 300 watt power pack just stopped working. The lights can still be turned on/off manually. Anything I can do other than buy a new one?
Unfortunately when the power pack stops working there is no solution.
Your power pack has electricity so that is not the problem.
The bulbs turn on, so the bulbs are ok.
That means the power pack has malfunctioned, and needs to be replaced.
I did find some tips to help folks preserve their power packs:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
Nov 12, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
The transformer will work if I manually turn the dial. The dial will not automatically turn anymore.
If the bulbs turn on when you manually rotate dial, then the power pack has electricity.
A lot of people ask for replacement Malibu tripper pins on Fixya, and it sounds like your trippers are working fine.
If clock has stopped rotating, that means the power pack has malfunctioned, and needs to be replaced.
Nov 11, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
Canon Powershot SD1000 Lens won't focus
If you can get a hold of some dry nitrogen and setup a vacuum bottle of some sort using the food vacuum storage bag machine. Place the camera in the bottle. Seal the bottle with a top that has a dual vent idea where they both have a valve shutoff . One to the vacuum one piping in the nitrogen. Nitrogen is a no lethal non flameable drying agent they use in Binoculars to prevent fogging of the inside lenses.. Shut the Nitrogen side gas off. too. Open the vacuum side and pump down as much as possible there will be a max I do believe minus 25 foot pound per cubic inch of Mercury! Nature of this beast. Now shut that valve the camera is now vacuum packed. Turning on the Nitrogen open that port to the vacuum slowly not to make a sudden pressure change and let in all the Nitrogen it will take without blowing off the cap! If it is a pickle jar the top will pop like opening a sealed jar of pickles. .
Any moisture the nitrogen touches will be removes. This can be done if the camera's parts are not air tight. If they are then this problem would never had happened...
Simple and a cost of a very small jar of compressed Nitrogen is way less than 40 dollars. The vacuum machine should be a household item since you can afford a digital camera because you do preserve food and leftovers in savers bags
Jul 24, 2009 | Canon PowerShot SD1000 Digital Camera
What is vaccum packing?
Vacuum packing is a method of storing food and presenting it for sale. Appropriate types of food are stored in an airless environment, usually in an air-tight pack or bottle to prevent the growth of microorganisms. The vacuum environment removes atmospheric oxygen, protecting the food from spoiling by limiting the growth of aerobic bacteria or fungi, and preventing the evaporation of volatile components. Vacuum packing is commonly used for long-term storage of dry foods such as cereals, nuts, cured meats, cheese, smoked fish, coffee, and crisps and also for shorter-term storage of fresh foods such as vegetables, meats, and liquids such as soups.
Vacuum packing is also used to reduce greatly the bulk of non-food items. For example, clothing and bedding can be stored in bags evacuated with a domestic vacuum cleaner or a dedicated vacuum sealer. This technique is sometimes used to compact household waste, for example where a charge is made for each full bag collected.
Please rate this fixya
Jan 29, 2009 | Vacuums
Hardware & Accessories Logo
44 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
