Spins slow And it seems as tho the agitater is still doing its thing ( may be what's slowing down the spin !
    Top Expert:
  • Washing Mach... Master
  • 8,376 Answers
See if this link helps you out if a popup comes up just close it down..
DIY Washing Machine That Spins Slowly eHow
Posted on Dec 13, 2016
Our whirlpool wfs1285aw doesn't seem to be spinning and drying out clothes enough when Finished. The clothes are still drenched. Any ideas how to rectify this? Is there a filter that needs cleaning?
the rinse section spins slow while the rinsing is in process as this does 2 things
spreads the water through the clothes for a proper rinse
spins slow to equalize the cloths around the bowl
when the rinse cycle is finished and the tap is shut off it goes into a high speed spin
Your problem sounds like the program is not going to the high speed spin cycle and that would indicate a problem board
call a technician for a proper diagnosis and quote
Sep 15, 2016 | Whirlpool Washing Machines
13.5 hp Tecumseh engine. Why is it hard start and slow to spin?
Patrick, be sure battery and starter are good. all ground and hot wires are good. sometimes a bad connection can cause a mower to spin slow or not at all.could be many things. but take the spark plug out and if it spins fast out but spins in a bind or on a compression stroke slows or stops with the plug in, could be valves need adjusted.
Jan 23, 2016 | Garden
2006 Honda XR 125 L - 5
Check calipers and seals clean and free the brake pistons if any seals are pinching replace them
Jan 26, 2012 | Honda XR 125 L Motorcycles
GE JVM1430 over the range microwave/exhaust fan unit. The exhaust fan (not the microwave cooling fan) all of a sudden has its speed slowed down considerably. The unit vents out the back, not top. ...
Sounds like a strip down of the fan and lubricate the bearings with sewing machine or thin cycle oil will do the trick.
Hope that helps.
Jan 20, 2011 | Microwave Ovens
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
I have a GE wcx1070 and it will not agitate or spin will fill the tub and drain but won't spin. I have checked for obstrutions in the tub and under the agitater. and the belt looks good if it does spin it...
I think it might be the lid switch. 8e3407e.jpgas you can see it can fail mechanically and electrically. To get to the lid switch you remove the front panel firstf373b4d.jpgthen you can remove the top and access the slid switch.
Use this training manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 06, 2010 | GE WVSR1060A Top Load Washer
Seems to be slowing down. I have checked wires on
left motor in low & both in high gear spin!
and only one spins for reverse!
if it sems real slow then thee battery may eed replacing!
try this mob for parts worldwide
Cheers Rob
">yhst-49586367436770_2067_111901090
Aug 11, 2009 | Peg Perego John Deere Gator HPX Ride on...
Washer spins but too slow
Clean out the drain pump. Sounds like water is pumping out too slow. This added weight is slowing down the spin.
If water is pumping out OK and you still have the same problem, replace the drive belt.
Apr 01, 2009 | GE Washing Machines
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag Performa Washer spins fine but stops instantly
Check the unit next time it is in the spin open the lid up does it do the same thing?? if so it is working ok that is the Brake in the unit doing it Job but if it is really loud it maybe going out??
Jan 26, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
