Question about Briggs & Stratton Garden
My exhaust silencer fell off and the threads on the block are damaged. Whats the best way to repair it?
    President:
  • 1,273 Answers
Usually, the best thing to do is remove/replace the studs.
Regards, --W/D--
Posted on Jul 21, 2009
How do we repair silencer dent
a silencer dent gives the bike character even a different zorst sound
can you buy a silencer protector for the 180?
might cover the dent
heating up and cooling it wont help much
you could try and cut out the dent and fit new metal
will look ugly
pulsar 180 exhaust
Sep 05, 2016 | Bajaj Pulsar 180 Motorcycles
Pickup and power prblms
have you checked exhaust port and exhaust not carbon up ? rear silencers can clog up or break inside , if you can remove silencer and run up , it will be loud but see if it revs better !
Dec 29, 2013 | 2005 Honda Unicorn
Exhaust leak
exhaust leaks are common, and very dangerous.
if parked say in a snow bank , you can get CO death easy.
odorless and fall asleep (no pain) death.
so keep car out side, and not near snow....
safety first.
first off, i dont know what back means.
the exhaust on most cars runs from front to rear.
from 6 feet to 10 feet.
exhausts can leak for a variety of reasons.
1: bolts fell off.
2: gasket failures
3: cracks.
4 :rust through.
5: parts fell disconnected due to clamp failures.
6: road hazard damaged.
on cars, damage has no limits. (moving running cars)
so what we d,o is have a professional look at it (ASE mech)
to see cause and damage and suggest solutions.
one other way is to take a photo of said damage
or point to crack, in photo and say,
what do you think.
then an only then can a web bunny help you./
Dec 28, 2013 | Toyota Cressida Cars & Trucks
Starter mounting bolt has falling out of block on 04 impala
Hi. First you need to try and establish why it came loose if possible. Best solution is to remove the bolt and inspect the bolt threads to see if they look damaged or stripped. If they look ok wind it back in and try to feel if it winds in smoothly and tightens up properly. If it is very tight as you wind it in or slips when tightening then you may have stripped/ damaged threads in the bolt hole. If it goes in and tightens ok then you can pull it back out and put a small drop of thread lock on the tip of the threads(local motorist store will sell it). don't put more than a drop on or next time you need it out you will struggle and finally check the other bolts for the starter. Jon
Dec 09, 2013 | 2004 Chevrolet Impala
Got hit in the back of my 1995 villager yesterday, since then it keeps back firing and over heating, i have changed the distributor cap and rotor, some guy told me it could be my catalytic converter.. need...
Sounds like your exhaust may have got damaged in collision Check it hasn't been crushed or badly bent. Catlyst converter or silencer may have been damaged. All in all it sounds like a blocked exhaust
Aug 15, 2011 | 1995 Mercury Villager
I have an 81 kawasaki ke 125. I was riding the other day for about an hour and it suddenly started to backfire and billow white smoke. When it started to backfire it lost a lot of power. It will also not...
Could be that you have blown the piston rings, firstly i would remove the rear silencer, as 2 strokes bellow out exsess smoke and loose power when the silencer becomes blocked due to carbon, start and run the bike and check without the silencer, furthermore to eliminate the exhaust itself is blocked, undo it from the cylinde
Jul 31, 2011 | 1981 kawasaki KE 125
My silencer is blowing between the silencer and the link pipe how can i repair it
Remove the silencer and clean up the down pipe and silencer ends. Use a liberal amount of exhaust repair paste and push the silencer back on. Refit the clamp that holds the pipes together and replace any perished rubberised band that may be used. Run the motor on idle for about 10 mins to harden the paste and the leave overnight. Recheck the clamp for tightness and hopefully all should be well with the world, the sun will be shining and you can go for a ride.
Mar 03, 2011 | kawasaki ZXR 400 Motorcycles
Stuck silencer in after market exhaust
It is welded internally, there is no way to get it out as far as I know.
Apr 07, 2010 | 1997 Mitsubishi Eclipse
Silencer Damaged
It is fiberglass. You need to replace your exhaust sustem with one designed for your motorcycle. Please see your local dealer for replacement
Thanks for your question at FixYa.com
Dec 28, 2009 | 2005 Bajaj Pulsar 150
Water in DEP silencer exhaust
drain your crankcase's oil and check underneath the stator cover, moisture does funny things in there. as for the exhaust just keep running it, maybe the baffle inside cracked up and fell apart a bit inside.
Nov 26, 2009 | 2003 Yamaha YZ 125
Garden Logo
108 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
