Try not to **** up any more water. Don't use until you can dry it out well. Hopefully you live in a warm climate so that will happen sooner than later.
D17 POWER STEERING has had spots when moving the wheel. It's not smooth steering at all and with a load you have to front be moving with the wheel turning real slow.I've drained the reservoir and replaced the suction hose.
Most treads have two bolts on the rear roller. To tighten turns these bolts clockwise. Depending on how bad the problem is, I usually turn a 1/4 turn at a time. Walk on the machine to check tension. Once tension is correct turn right side bolt or left side bolt to center belt. Remember belt will travel to side with least resistance. ie.. if you want the belt to go to the left- tighten the right side(clockwise) Centering the belt is easier with machine running at about 2-2.5 if belt is not rubbing on the sides.
