Question about Amtrol Water Heaters
I have an Amtrol WH7Z water heater that is barely making hot water is there a heating element that needs to be changed?
    Top Expert:
  • Amtrol Master
  • 77,932 Answers
Is this a gas heater or an electric?
Posted on Dec 13, 2016
ER3 error code on amtrol hot water tank
Simply means hot water heater called for heat for 1 hour and never rose in temperature or reach stepping, unit automatically goes into lockout. I would reset power
Feb 14, 2015 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
Jan 19, 2014 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
AMTROL Boiler Mate no hot water
You might have bad faucet cartridge or check valve.
Possibly a clogged line.
Contact amtrol to hear them suggest calling local technician
Otherwise Amtrol does not post service information or service manuals.
Post question on pro water heater forum to hear them suggest a few things before you call local service technician.
Use search feature on forum above, before calling local service technician
Read suggested answers at fixya before calling local plumber.
Call amtrol and ask why they do not post service manuals or service information when so many promoters are selling the product.
May 17, 2013 | Water Heaters
Wh 9L amtrol water heater..the water temp is too hot.. the heater is 10 yrs old is it possible to remove the temp probe and clean?
Amdrol makes indirect-fired water heater that gets heat from a boiler
1) Pdf manual on amdrol website show a mixing valve that mixes cold water with the hot water so water temperature going to faucet stays the same:
You set the temperature of the mixing valve.
You can also set up 2 sets of pipes ... one is connected to mixing valve that goes to sinks and tubs. The other pipe bypasses mixing valve sends hotter water to washing machine.
2) The manual for Amdrol:
The new models has a temperature sensor that plugs into digital readout.
This is a thermistor sensor wire that can be ordered as repair part
3) Amdrol has e-mail address:
4) You can post your question on a water heater forum
Nov 11, 2010 | Amtrol Water Heaters
Not heating water hot enough or as much water.
You probably have a bad heating element. Probably the upper element.
Feb 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Amtrol water heater WH-7P gets barely warm water
From what you are saying it sounds like an issue with either a circulator pump or a zone valve. It depends on what type of system you have ... if you have a circulator pump that only runs the Amtrol then that is probably bad. If you have a zone valve system then it is probably the zone valve if you still have heat for the rest of the house. If you have no space heating then it is probably the circulator pump.
Nov 04, 2009 | Water Heaters
ER3 no hot water
Er3 means that the water is being heated for more than 1 hour without reaching the set temperature.
Need new aquastat.
Sep 28, 2009 | Amtrol ST-120V-C THERM-X-TROL ASME...
No hot water at faucet
may need new circulater or bleed air from that zone
Apr 14, 2009 | Water Heaters
My water heater is buzzing then shutting off. (no hot water)
the power interrupt switch is detecting a short in one of the heating coils.  With the power off remove the side cover pull out the insulation and disconnect the wire to one of the heating elements.  Make sure it isn't touching anything and turn the power back on and see if the problem continues.  If it does reconnect the wire and do the same to the other heating element.  Be careful.  If you feel uncomfortable doing this call an electrician.
Mar 30, 2009 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Amtrol Smart Controller 2704A233
jump out the relay that the amtrol runs off of till water heats up then shut off,dont want it too hot
Mar 30, 2009 | Water Heaters
Water Heaters Logo
Top Amtrol Water Heaters Experts
Paul Carew
Level 1 Expert
Are you an Amtrol Water Heater Expert? Answer questions, earn points and help others
