What do you do when the OE code comes on , I was starting and hitting spin . But now it want do anything
  • 59 Answers
If it is a samsung look in the back of the owner manual it tells you the code meaning. It could be door seal, load dispersal.
Posted on Dec 13, 2016
What are the common fixes for OE Error Code?
OE error code is an Outlet Error.
That has to do with the drain itself. It can come up when the unit is draining slowly, it has nothing to do with water-level really. I would suggest makign sure that your drain hose is not crimped / crushed / or obstructed first before going onto other problems.
May 02, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
How do you fix Error Code OE on defy laundromaid electrologic 1300 ? Machine washes, but when it should start to spin, nothing happens - it's just making a noise for a while, no water releases and then...
If draining is not completed in a specified time limit the fault code OE will be displayed.
Check the drain hose is free (not kinked or deformed) and check there is no dirt in the drain filter.
The filter is located behind a cover on the kick-panel at the front of the machine.
May 01, 2014 | Washing Machines
Front loader will not spin
oe code is pump blocked, but because you have cleaned it, make sure the pipe from pump is not blocked
Feb 04, 2012 | LG Washing Machines
Oe pops up and door is locked what do i do
OE is a drain motor error, or your drain hose is kinked, check to see if your hose is kinked on the back of the machine.
Once you check to see if the hose is kinked, press the power button on the unit, then hit "spin speed" and select it to "no spin", and then hit "play". This will manually set your unit to drain mode. If you still get this error, you will need to replace the drain motor on the unit.
Mar 30, 2010 | LG WM1814CW Front Load Washer
The washer is not pumping out water..code is OE ??
OE, means your drain is clogged, or the hose is kinked up. What you need to do, is get some towels and and tupperware bowel or a long pan. You'll need to open the front access door on the bottom. You can manually drain the water with the small hose on the left, or you can drain it from unscrewing the big cap. If you unscrew the cap, you'll need to unscrew it slowly, so the water does not come rushing out.
Once you drain the water, go ahead and pull that cap all the way out, and see if there is anything stuck in that filter, if it is, pull the debris out. Start your washing machine, and try the Rinse+Spin cycle, and start it up. See if you get the error code anymore.
If this does not solve your problem, you may need to call for service, or go a step further in accessing the drain motor, via removing the front cover of the washing machine.
Let's try to above steps first, then we'll move forward if that does not fix your problem.
Mar 28, 2010 | LG Washing Machines
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD-12AW2
this unit has an anti flood device. if it leaks it lifts a piece of plastic in the base and hits the microswitch. try leaning the unit to one side and i would put towels down. if water comes out then try a program. hope this helps.
Feb 12, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
