Question about Plumbing
Western flostat pump leaking fluid between motor base and pump seal?
    Top Expert:
  • Plumbing Master
  • 50,533 Answers
Replace the pump seal
there is a bellows type carbon on ceramic seal that over time the rubber cracks , or if run without water will damage the carbon seal surface on the ceramic base
any pump or irrigation shop can affect the repair
Posted on Dec 13, 2016
The rear washer on my 2012 Tahoe works fine. The front washer does not. A small amount of fluid will come out if pressure is blown into the fluid tank..
can you here the washer pump run when trying to use washers?
if not replace pump if yes,use compressed air and blow back through nozzles. Its possible they are clogged
Apr 06, 2015 | Chevrolet Tahoe Cars & Trucks
Lazy spa pump leaking from the base
as the seals leak they ruin motor bearings replace whole unit less hassle
Nov 09, 2017 | Pool & Spa
Pump leaks from the bottom after running, is this normal?
No . the problem is that the ceramic seal that seals between the fluid and the motor and bearings is leaking ( probably from running dry) or the rubber that holds the carbon seal insert has a crack. Suggest you pull the pump down to fix it otherwise the water/ fluid will get into the bearing of the motor and will cause a major failure
Aug 12, 2013 | Grundfos MQ3-45 1 HP Pressure Booster...
Corrosion in submersible pumps
As long as the fluid is not corrosive to the pump material, the fluid pH is 8.5 to 9, and the pump is always submerged, corrosion will not happen. What's your problem regarding hydraulic loading? are you getting less than what is designed?
Seal leak is caused by worn shaft, corroded shaft, worn seal material, seal material not compatible with the fluid, and wobbling shaft due to defective bearings.
Oct 15, 2012 | Simer Submersible Deep Well Pump (ACE...
Transmission fluid leak
It is the front pump seal of the transmission,the transmission has to be removed to replace the seal.
Apr 11, 2010 | 1998 Ford Expedition
My 2000 jeep wrangler sport is leaking fluid just under my front differential. whats wrong?
change the front pinion seal and check the axle seals for leakeage
Jan 13, 2010 | 2003 Jeep Wrangler
Leaking hot tub motor
hi! there,
well occassionaly leak on pumps this is due to the mechanical shaft seal has been worn out.If you can do fix your self
try to prepare tools to be used mostly set of socket wrench,set of open and closed wrench,pipe wrench one pair,screw driver flat and cross,switch off circuit breaker of pump motor,disconnect elctrical wiring of pump motor,disconnect pump pipe fitting usually on union service fiiting, if pump is free from fitting loosen bolt on pump motor base,pull out pump motor place on a particular working table,have a prepare box to place all bolt to be disconnected on pumps,we have to pull out motor from pumps housing assemblyd217218.jpg
have you seen hydro pump,the motor assembly was couple to pums assembly.thereare 4 long bolts connected holding motor to pump assembly at the back of motor loosen this to disengage
motor and pump assembly,try to put mark on motor back cover
for reference in putting back.if motor is disengage on pump assembly, of course the rotor of motor still connected on pump assembly.
the shaft seal is connected to the rotor shaft inside pumps assembly,there are 4 bolts holding pump casing front cover loosening this will appear the centrifugal blade connected to rotor shafting holiding by a big nut at tip of rotor shaft.loosen this by socket wrench try to find the size,then pull centrifugal blade with
the shaft seal,buy this one with same specification exact value of shaft seal,if there is mistake buying seal either leak again or to tight.shaft549ea12.jpgso this type is just sample to have idea,afterr you purchased put it back and reassemble the pump motor.thi is easy one, have a nice day don't forget to rate me. thank's
Apr 11, 2009 | Home
Transmission fluid leakage from stater motor area. 5.7L Vortec
If transmission fluid is dripping off the bellhousing your torque converter seal is leaking or your transmission pump seal is leaking. Chances are the torque converter seal is leaking since the torque converter is spinning on it any time the engine is turning, the pump seal dosen't move it just keeps fluid inside the transmission. Even though it leaks with or without the engine running I'm willing to bet if you got underneath it with the engine running you will see it leaks more with the engine running. Now if either seal is leaking it will require the engine to be removed from the transmission to get to the seal. Sorry but this isn't going to be a cheap quick fix.
Apr 01, 2009 | 2001 Chevrolet Express
Plumbing Logo
246 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
