Question about Hotpoint Washing Machines
Why does the ariston hotpoint washing machine beeps? It works perfectly fine it does the work really good. but the only thing is that its beeping randomly all of the time the machine is washing. Why?
  • 59 Answers
It could be signaling when the machine is changing cycles so you can add liquids, take out or add items or let them soak.
Posted on Dec 13, 2016
SOURCE: Washing Machine stopped through cycle and now will not turn on
Unplug!!! NOW! I drained the water using a common garden hose, fill the hose with water and have some device turning it off like a trigger nozzle on the low end. Detach from the supply and put the supply end in the center of the tub under the softener dispenser. take the trigger nozzle off and watch the water drain without cups and buckets. Then wring out the clothes and put them aside, use the hose trick again for remaining water. Now get under the washer and detach and reattach the brown and white lead input to the rinse cycle motor. She is made in France so be gentle. Plug the machine in and set the machine down and turn it on. Push the >> button until you reach the spin cycle if it starts you have fixed it!! Put the clothes back in open a bottle of wine and try again.
Posted on Nov 05, 2007
  • 3 Answers
SOURCE: very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Posted on Dec 06, 2008
  • 2651 Answers
SOURCE: FIsher and Paykel washing machine won't stop beeping.
if you remove the back panel you can look under there, there should be atrouble shooter/techsheet that will let you know what the flashinglights mean. if not theres a tech support number to aid you as well
Posted on Mar 02, 2009
SOURCE: 1 beep per second and odd light sequence
there some simple solutions but may not always work but everyone should try. underneath when the water pump engage with the tub. there;s a white plastic clip press it out and turn the water pump. it will come off the tub. before doing this you should have the washer disconnected. have someone or put something under so the washer won;t fell on you while reaching down. sometimes debris gets stucks on the way from the tub to the pump. it insert your fingers inside once the pump is taken out and if you find debris take it out. put back the pump and connect the washer again. this can be a very simple solution it won;t work all the times. but what if it does. :)
Posted on Feb 25, 2010
  • 9472 Answers
SOURCE: My washing machine will lock the door, start the
The F11 error code is a communication failure between the 2 control boards. This includes both boards & the wiring harness as potential defective components. However, this is usually the main machine control board that needs replaced.
Posted on Feb 12, 2011
Wont start, no error codes, what could be the problem?
I would check the lid switch.
These switches are normally made of plastic, and are made really cheaply, and break often.
When they break the washer will no longer start.
Have someone raise the lid and check it out.
God bless your efforts.
Jul 11, 2016 | Hotpoint-Ariston Washing Machines
My washing machine has started beeping during the wash cycle - why?
Try running the same wash cycle with no clothes in the machine, just the water.
If it does not beep you are overloading it or the load is unbalanced.
Dec 20, 2015 | Hotpoint Aqualtis AQ113F497E White 595 mm...
How do you change the langauge on the hotpoint ariston eco7d149 many thanks
no guarantees here, but I think that you need to turn the machine off using the on/off button on the facia.
Once it's off, press and hold the 3 centre buttons (There are 5 buttons, so do NOT press the far right and left ones) until the machine beeps.
Let go of the buttons.
Turn on and it should start the set up from the beginning.
Jul 01, 2011 | Washing Machines
Error F-05
pulled out filter- golf tee jamming it, now works fine. hotpoint were going to charge me £100 to fix it,as it was something you can't do yourself!!
Oct 24, 2009 | Hotpoint Ariston AW125 Front Load Washer
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Ariston Elixia LI68 Duo dishwasher will not start
Same problem , i fixed by opening the door compleet then cleaning the bottom of the door with a kitchen cleaning paper that may do it afther that disconect the power compleet whait 1 minut connect it al again and it should work , don't ask me why this cleaning action i just found it out
Feb 05, 2009 | Ariston Technologies Dishwashers
Washing machine wont start - close door message
Most likely faulty door lock or door catch.
To access it, remove the clamp from drum front seal, and remove the seal from the front of the cabinet, undo the 2 screws that secure the door lock, and remove.
To test wether the lock is faulty or not, put a link wire across the (L) and (C)
connections on the lock, the m/c should now work, if it does not, then you have
a more serious problem.
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My hotpoint ultima plus washing machine door wont open after wash
Hi,I have a 2nd hand Hotpoint Ultima digital washing machine & cant seem to use it as when i turn it on on display screen the childlock icon flashes & beeps,even when door is open/closed,when i select a programme the icon still flashes & beeps therefore i cannot use machine.hope you can help me with my question Thanks.GILLI37
Apr 14, 2008 | Washing Machines
Washing Machines Logo
180 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
