Question about GPS
How do I recalibrate my touch screen.when I'm typing on my keyboard it won't register my Finger sometimes when I touch the screen
  • GPS Master
  • 19,031 Answers
You can't, this is a problem with this type of screen. It is worse in colder weather. Make sure you fingers aren't dry.
Posted on Dec 13, 2016
How do I calidrate the digitizer ?
What kind of phone do you have?
but try this:
You could try recalibrating the touchscreen by going to Menu, Settings, Language & keyboard, Touch Input, Text Input, under Finger touch precision, choose Calibration tool or even Reset calibration. If it still happens, you may have a bad screen which should be covered under warranty.
Dec 04, 2015 | Cell Phones
Garmin nuvi 265w screen out of sinc
Try recalibrating the screen.
Nuvi 2xx/2xxW Series: Turn the Nuvi off. Place your finger on the upper left-hand corner of the screen and then slide the on/off power switch to the left and hold until you see the calibration screen. Note: Some 2xxW models require the procedure below for the 7xx.
Nuvi 7xx Series: Turn the Nuvi off. Touch the screen anywhere and keep your finger there while moving the on/off switch to left (don't wait for Garmin logo to come up) and then quickly moving the switch the right (lock position). After a short while, you will reach the calibration screen. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Apr 05, 2014 | Garmin Nuvi 265W GPS Receiver
My touch keyboard doesn't work
You need to recalibrate your touchscreen. If the screen can not be recalibrated, then it needs to be replaced. Please see this link on how to recalibrate your touchscreen:
Use the Nuvi 14xx procedure
http://www.sharc.net/discus/messages/6/77.html?1315261162
Apr 10, 2013 | Garmin Nuvi 50 LM
Lanier LD435c touch screen is not registering touch in right plac
Press the yellow clear modes button then press
1 9 9 3 and the red clear/stop botton 5 times
this will open up the touch screen calibration menu
select calibrate touch screen. follow on screen directions.
Good Luck
Apr 08, 2010 | Office Equipment & Supplies
Keys on keyboard don't register when I type, also they stick
Well like you said 2 months old only claim the warranty and have it replaced with a new one.
Dec 15, 2009 | Logitech Wireless Access Duo Optical...
Garmin nuvi 205, sometimes it won't respond to my touch. Sometimes when I go to give it a name or address it just keeps repeating a letter, "aaaa, or jjjj. then when I touch the botton to go back or clear...
Your touch display is shorting out....BAD
Replace Unit
BUT try this first:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
Does this help? Let me know. Thank you...
Nov 03, 2009 | Garmin nuvi 205 GPS Receiver
My Garmin nuvi 200w behaves erratically until it has been turned on and warmed up for around 10 minutes. Before this time the touch screen may not work or when pressed respond as if pressed at another...
First make sure the batteries are good and at normal room temperature.
Second, based on your question your touch screen is bad or needs calibrating....
Then
Try to recalibrate your screen:
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
I'm getting inaccurate letter entry on the letters I type. For example, when I type a B an M appears - I'm noticing it on the bottom row of letters at this time. Solution?
Are you sure you pressed the correct location on your screen???
If so, you may need to calibrate the screen.
Do this:
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Have got Garmin nuvi 710touch screen will perodicly freez and i am unable to turn the unit off or on
In order to recalibrate the nuvi® 7xx's touch screen, follow the instructions below.
  1. Start with the unit powered OFF and unplugged from power supply.
  2. Press and hold your finger anywhere on the touch screen
  3. Next, slide the power switch ON and immediately slide it into the Lock position. There is no need to wait for the screen to flash on or show the Garmin logo before moving the switch into the Lock position.
  4. Leave your finger on the screen for about 45 seconds.
  5. Two intersecting lines should display on the screen along with the message: Press Dot.
Follow the rest of the on screen prompts to complete the screen recalibration. Once it is completed the unit will display Calibration Complete
Oct 13, 2008 | Garmin GPS
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
