My TS4500 works in reverse but not in shred even when the green light is on. What can I do about it?
  • 2,944 Answers
Dear Wayne.
I tried to be a shredded service person, and I suspect your problem is inside the machine where you cannot see it.
I think the cutting heads are clogged with paper and/or bent.
I have repeatedly ordered cutting heads ( from different companies) and been told they were back ordered, because they were made overseas.
Try taking your machine all apart, and I hope your repairs are more successful than mine have been.
I finally gave up and replace them with those symptoms.
God bless your efforts.
Posted on Dec 13, 2016
My royal sp12mx will work in reverse but nothing happens when i insert paper to shred. light is on
there is a very small lever between two cutters around the middle that activates a microswitch to turn it on when you offer paper to be cut
the problem will be in that area ( switch or lever broken) as it's purpose is to switch on the cutters
reverse is straight drive from the control switch
Aug 27, 2016 | Royal SP12MX 12 Sheets PP Security Plus...
How to restore shredding capacity?
Access the mechanism and spend some time picking out all the bits of paper jammed in it.
Aug 22, 2016 | Office Equipment & Supplies
RED Light is on (left of the green light)
Reverse shredder and clean out as much paper shred as possible. Use some lube oil. Hairclipper oil and canola vegetable oil are good choices.
Aug 26, 2015 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
Tech Solutions shredder Only powers in reverse w/ green light
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
Jun 01, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
Infoguard SX100M unit will not shred. Green light comes on.
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
Anyways, I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Jan 10, 2009 | Cross Infoguard Shredder SX102M
Red overload light is on
Try pouring some shredder oil into the throat where you normally insert the paper and run the machine in reverse.Put machine back into ready condition.
Put a piece of paper in the throat just enough so the machine should run but not all the way in so that the cutting mechanism catches the paper...all you want to do is make the machine run forwards but not actually be feeding in any paper.
If it wont even run in the forward direction you may have a pcb prob...give Royal a call at 1-800-524-0799 for parts assistance.
Jan 08, 2009 | Royal VF1012mx Shredder
It sounds like you may have a gear with a broken tooth you should contact the manufacturer to get more info. Usually when this is the case it will shred good for only a few revolutions and then reversing backs the gear up to a position that allows it to turn the cutters until it once again reaches the area where tooth is missing.
Mar 11, 2008 | Winsource Tech Solutions TS-4500 Cross-Cut...
Shredder Problem
Replace the paper sensor switch
May 27, 2007 | Tech Solution TS-4500 Shredder
78 people viewed this question
k24674
jasbo
jasbo
