Question about Panasonic PT-50LC13 50" Rear Projection HDTV
WHEN I TRY TO TURN ON MY PT-50LCGREEN LITE FLASHES THAN TURNS RED
LAMP APPEARS TO BE GOOD
    Problem Solver:
  • 13 Answers
Your Balister is shot. Go to consumer affair and search on your TV model, there are all types of issues. Please file a complaint and join our growing list to get Panasonic to support its customers.
Posted on Aug 28, 2009
It shutts off ramdomly the red lite blikes an have to what for green light to come on before it turns back on
Tv "LAMP" LED lite indication flashes or staying on?The tv projection lamp life is over.The projection lamp require changing.
Aug 06, 2010 | Panasonic PT-50LC14 50" Rear Projection...
PT-56DLX75 turns off red light flashes. Replaced
You need to first CK power supply board for Bad capacitors they will be vented,swollen or puffed up on top ,if you do not see any then try replacing Ballast Board it is what Powers Lamp. Call Encompas Parts Dustrubtion for Part numbers and Prices or Visit teir Website online!
Mar 24, 2010 | Panasonic PT-56DLX75 56" HDTV
PT-61LCZ7 is recently slow to turn on. flashes red for a long ti
Replace your Lamp visit Encompass Parts Distr online look up your model number or Call 1-800-638-3328 If Lamp has already been replaced then it will be either a defective Fan or Ballast board which is what turns Lamp on Make sure all Fans are running.
Nov 30, 2009 | Panasonic PT-61DLX75 61" HDTV
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
PT-AE700U Lamp led flashes red
Reset the lamp hours. Here is the manual on how to reset lamp time.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and Please Rate Fixya!
Feb 28, 2009 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT50LC14 No Sound or Picture
unplug it, and let it set for a minute or 2, then try it again...if it does it again hit the power button again to turn it back on...also once the the tv turns on make sure you reset the counter for the bulb..that will also cause problems...to reset the counter press the (-) volume on the tv while holding down the (-) press spilt,pip on the reomte...the lamp will reset and the indicator will go out
Jan 20, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Green power lite blinks but does not turn solid green
check the lamp...lamp cover under front panel on left... take out lamp (unplug TV befor doing this) and see if it is broke ....if lamp is good replace it and put it back together plug set back in and try it agen some times the conector dont make good contect so just taking out and in fixes it..... also lisen to the set when you turn it on most of the time there is a little buzz when it is trying to fire the lamp if the buzz is not there it maybe the ballast board
good luck
Nov 11, 2008 | Panasonic PT-50LC14 50" Rear Projection...
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Apr 21, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
130 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
