My TV keeps saying no signal. Tested a working aerial from another TV and still states no signal?
    New Friend:
  • 3 Answers
Just check the setting of your TV.
Posted on Dec 13, 2016
Highdefjeff
  • 124 Answers
SOURCE: Freeview wont work
Have you changed to "source" or "mode" or "input" to correspond to the different inputs?
Posted on Apr 08, 2008
  • 905 Answers
SOURCE: I'm not sure where to plug into the tv the aerial lead
the end of the antenna wire will screw on a threaded antenna connection on the back of the tv
looks like this type of connection
Posted on Mar 21, 2009
SOURCE: No instruction manual.
You can download a pdf version of the quick guide and user guide at http:downloadcenter.samsung.com.
Hope this helps.
Posted on Jul 02, 2009
  • 5 Answers
SOURCE: no TV signal
try a different aerial if that doesnt work do a factory reset and then redo your first time installation
Posted on Jan 04, 2010
brownline45
  • 310 Answers
SOURCE: Having brought my television back from the caravan
just connect the cable then try to retuned. but no funtion?maybe the tuner is being damage due to caravan or there is a loose connection inside the tv
Posted on Jun 19, 2010
My Alba TV , when scanning for channels ,says no signal, check antannae, which i have by connecting a different tv, its working good , but my tv not showing any channels when even using first time ins
Check and replace the tuner inside the TV. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 01, 2014 | Alba LDVD1538WDCH LCD TV
I cant get free view to work on the logik tv how cani get it to work it keeps saying no sigbal would a indoor aerial work or what do i need thanks for ur time!
0463b152-37bc-4ebb-bb92-c047a902bf0c.jpgDigital TV's need good aerials or you might finish up with some stations or none at all. Indoor aerials will only work if you live in an area that has strong signals from the transmitter. You can ask your neighbours if you need a proper aerial or not.
Ideally the above type of aerial is best.
Sep 19, 2013 | Sony SLV-640HF VHS VCR
My sony Bravia KDL-37P55xx seems to be recieving no signal from our aerial. I know the aerial works as I have checked it with other tvs in the house. Is there a quick fix solution for this
Make sure that the TV is on the right setting, either TV for analog pictures, or DTV for digital. Run a complete auto-setup. This will wipe the tuner memory and re-scan. Hopefully this should sort the problem. If you have tested the aerial cable with another TV in place of that one (not just on a cable from the same aerial in another room) and it works but that one won't, then it will be down to a TV fault. If this helps, please rate me!
Jul 14, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Digital TV problems
You are suffering from a poor signal. Digital TVs will display 'blocking' (partial freezing of the picture in square or rectangular blocks) or total freezing of the picture, when the signal is too weak.
You don't say if this is a recent problem on a set that has been working correctly - that info. would be helpful. However, things to check include:
Has the aerial moved (wind?)
Are you using a new extension coax cable? If so try another one, as connections may be faulty.
If this a new TV, and you have not used digital previously, your aerial may not be high enough gain for a digital signal, but that is unlikely unless it's a nery old aerial.
Feb 28, 2010 | Philips TV Tuner Video Capture PCI Card -...
No TV signal
Jan 02, 2010 | Televison & Video
Just moved into flat and my tv keeps saying no signal but i know its ok? i dont have the manual with me
You will have to retune the TV to the incoming signal, if you have tried this & still get "no signal" then you will need to check the incoming aerial connection & if there is a good aerial fitted for the flat.
Oct 19, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
No carrier signal
Your area TV stations may have already switched to digital. If that's the case you will need a digital converter box. I'd check with your local stations to find out.
Mar 19, 2009 | Orion 19RTLB (Black) 19 in. Flat Panel LCD...
I`ve set up my philips digital terrestrial receiver DTR220 and i`ve scanned for all channels, but i can`t pick up any because my aerial is not picking up any signal. I`ve tried different, stronger aerials...
I actually moved my tele to the other side of the room to see if it would work in a different spot and it took me ages to get some signal by moving my aerial around. The signal still wasn`t strong and i didn`t have alot of the channels and then i turned it on a few weeks after and it was working perfectly. Don`t ask me why! :s
Jul 21, 2008 | Audio Players & Recorders
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
