Question about Home Security
My sentry safe won't open. It opened yesterday morning no problem - last night it wouldn't open. Changed batteries - still didn't open. Please help
  • yadayada
    yadayada Dec 13, 2016
    Do you have the override key>
  • 416 Answers
SOURCE: Sentry Safe A3819
Go to
Find your model (pobably in safe for business)
And download the manual
Good Luck
Posted on Dec 23, 2008
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
SOURCE: factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Posted on Dec 18, 2009
SOURCE: I can't open my Sentry Safe (model #2100)
The problem is in the latch so one solution is to sit on the box, squeeze the latch and it opens. Voila!! Stupid R&D!
Posted on Aug 10, 2010
SOURCE: The Sentry V260 safe will not open. Replace batteries?
Locksmiths agree on how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place. How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Posted on Sep 28, 2010
Why won't the bolts on the left hand side of my sentry so310 safe not retract when the safe is opened, now I can't close my safe?
i just got robbed june last year the safe just let them know what to take put private stuff in a night stand or storage ben of some sort
May 17, 2014 | Sentry Fireproof Safe
Open sentry safe key
contact sentry safes customer support or your local locksmith
if in Fort Lauderdale area try
Mar 23, 2014 | Sentry Safe SentrySafe Safe. Fire Safe 1.2...
Somehow can open my sentry s3877 with the keypad.
A Safe and Vault Tech Will confirm that once you change the batteries the user code will erase and you will now have to enter the factory default that is in the owners manual and then use the programing instructions to program a new user code.
Jan 07, 2010 | Sentry Fireproof Safe
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
Sentry Model 1610 Won't Open
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
Oct 09, 2008 | Sentry Fireproof Safe
here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
Jul 02, 2008 | Sentry Fireproof Safe
Safe won't open
try this link
Apr 23, 2008 | Sentry Fireproof Safe
Small floor safe Sentry Model 3877 electronic lock and key
This manual will answer both of your questions.
Feb 21, 2008 | Sentry Fireproof Safe
Home Security Logo
61 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
