Question about Samsung Televison & Video
SAMSUNG 60in TV UN60EH6003F There is no stand by light when power plugged. But little later standby light blinking slowly then out WHEN UNPLUGGED! Can't turn on TV.
    New Friend:
  • 3 Answers
There might be problm in plug of your TV so just check it.
Posted on Dec 13, 2016
SOURCE: power light blinks red, TV doesn't turn on
if you are not technical i sugest you have this checked out by a professional most probably a fuse has gone from iside or your driver board has gone down. The blinking should be normal after you have turneds it off because some capacitors will be discharging.
Posted on Aug 24, 2007
SOURCE: samsung tv LE32R74BD standby light on but wont turn on
samsung tv le32r74bd had tv on standby and wont turn on,it is stuck on standby please can you solve this
Posted on Nov 24, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Posted on Feb 14, 2009
  • 86 Answers
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Posted on Mar 25, 2009
rulds2008
  • 3866 Answers
SOURCE: blinking red light, no picture or sound
You goingto need to replce the powersupply inside www.partstore.com should have it or preorder it for you from the manufacture i think there around $150 they could be cheaper. Another option is Ebay. thanks for using fixa.com please rate.
Posted on Aug 21, 2009
I have a Samsung model UN60EH6003F with sound but no picture. What part do I need to repair this?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 23, 2015 | Samsung UN60EH6003F 60-Inch 1080p LED-LCD...
No Picture Stand By Timer Light is blinking
Have to try switching on the the channel through your remote control? Sleep timer maybe On
Mar 01, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony KL-50W2U rear projection TV stuck in standby
Try holding down the power button until it turns off and then turn it on again.
Nov 29, 2012 | Sony KL-50W2U
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
After turning on TV, lamp light blinks but no picture
IF IT SHUTS DOWN TO STANDBY, THEN DIGITAL BAORD IS BAD, IF IT JUST KEEPS CYCLING ON/OFF THEN YOU NEED A POWER SUPPLY, BALLAST AND PROBABLY LAMP
Dec 30, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Jul 18, 2008 | Sony KV-35V65 TV
Sony tv wont turn on, standby light just flashes
I had the same problem guys! This is what I did:
My T.V. wouldn't turn on. The standby light was flashing six times, then four, then seven...I called Sony and they told me to unplug it for a couple of minutes, then try it again...didn't work....BUT, I have found a solution:
Try unpluging your T.V. for 4 hours+, then turn it back on. Worked for me! It's called a "hard reset" by sony. I had my T.V. unplugged for the whole day though.
Nov 18, 2007 | Televison & Video
Televison & Video Logo
50 people viewed this question
Jerry Greenberg
Jerry Greenberg
