Dear Tim
Disconnect the heater hoses from the engine block.
Using some steel or plastic pipe of the right diameter to fit inside the hoses.
Clamp the pipes inside the hoses, and attach a garden hose or a compressed air hose to the pipe to blow the heater core clean. Remember, the normal pressure that the core is designed for is about 15 # per square inch, so either normal household water pressure or an air compressor can blow the core to pieces, so be REALLY gentle whilst blowing it out.
God bless your efforts.
HEATER
CORE REPLACEMENT
If
its clogged it can be cleared with the use of Garden hose p[ump.The water has
to be turn into the heater hose line and then water has to be removed
out via the pump.
For
complete step by step procedure,refer heater core flushing and other help links
mentioned below.
Click
the link below:-----
http://schematicsdiagram.blogspot.com/2011/12/how-to-flush-heater-core.html
Click the link below:---
http://technoanswers.blogspot.com/2011/11/how-to-replace-heater-core-for-all-car.html
http://howtobyme.blogspot.in/2012/02/how-to-replace-heater-core-on-buick.html
http://howtobyme.blogspot.com/2011/12/how-to-remove-heater-core-on-2008-honda.html
http://howtobyme.blogspot.com/2011/12/honda-heater-core-replacement.html
http://technoanswers.blogspot.in/2012/02/how-to-replace-heater-core-on_10.html
These will help.
Thanks.
How to Flush Heater Core?
How to Remove Heater Core ?
Heater Core Replacement?
To replace heater core?http://technoanswers.blogspot.in/2012/02/how-to-replace-heater-core-on.html------How to replace heater core?http://technoanswers.blogspot.in/2012/02/how-to-replace-heater-core-on_10.html
----------This will help.Thanks.
For heater core replacing procedure. I suggest you to go through
this related help links.Its all complete step by step procedure: ----How to replace heater core for All car models?
Click the link below: ---
on Buick Regal?
