Vacuums Logo
M
Marc Cannon Posted on Dec 13, 2016
Can you please provide me with a Wiring diagram for an Oreck XL2 OEM Motor Replacement
1 Related Answer
Anonymous
  • 310 Answers
  • Posted on Jun 09, 2008
SOURCE: wiring diagram Oreck XL2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=650346
Wiring diagram Oreck XL2
Posted by geohil on Jun 06, 2008
Can I get a wiring diagram of the handle on an Oreck XL 2.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. The best place to get an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Motor smells Oreck Xl2
If it smells electrical, than you may need a new motor. If it smells more like burnt rubber, than you may have a brush or motor problem. To check you brush, take out the 5 screws that hold your bottom plate on the vacuum and remove the plate. Disengage the belt and see if the bearings at each end of the brush turn freely. If they do not, replace your brush. Also spin the motor shaft by hand and see if it turns freely. Hope this helps!
Install instructions orick power cord upright
You can find the assembly and wiring diagrams on this site to help you. Please check the correct model number as you have not provided this.
Oreck Upright Vacuum Parts
Oreck XL2 does not start.
There could be a problem with the cord. I suggest taking it to a local vacuum shop to have it inspected as that could be the problem
I have a oreck xl2 and while vacuuming the vacuum quit. The vacuum has the red power light on. Please advise
sounds like a bad motor. if the light is on at the switch and the motor doesn't run, then it could definitely a motor problem, worn down or dirty carbon brushes. the motor on these machines are not the best built, they require cleaning of the commutator yearly.
Oreck Orbiter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618779&thid=681757
Oreck Orbiter
Posted by eccott on Jun 18, 2008
Hi could you e-mail me a wiring diagram for the Oreck Orbiter please? I need to replace the mains cable & the cable to the motor. Thank you, Helen Eccott.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck Orbiter Floor Machines ORB-500… you can contact the customer service line / tech support @ the Oreck Factory that I will list below for you and they will be happy to help or assist you in the wiring diagram, please include the model # and serial # with your request. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
1helpful
2answers
Go Ahead. Use Us.
6helpful
3answers
Wiring
Here are the 4 different wiring for new Oreck motors.
1helpful
2answers
Wiring Schematices
I had the same problem after not paying attention to the connections when replacing my motor. I spent days searching for information and only found several non-answers with small photos that no one can read.I contacted Oreck for wiring information. They explicitly stated that they can't provide any wiring information for safety and liability reasons.
I found the Ametek schematic which shows the LINE and TAP locations on the motor.
Note: I have a 2600HH XL with 2 headlights.
Connect as follows:
3A, LINE: White lead w/piggy back terminal from light harness #1 & white lead from the power harness to the piggy back terminal
2A, TAP: Black lead from light harness #1
3B, LINE: White lead w/piggy back terminal from light harness #2 & black lead from the power harness
2B, TAP: Black lead from light harness #2
Top Oreck Vacuums Experts
john h
hsapiens
Level 1 Expert
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
