Question about Xantrex Technology Heart Freedom 20 12 Inverter
Heart inverter had over temp led on
I pulled out the TSC connection and now seems to charge fine. Do you think it is a problem to not use TSC?
  • sailunicorn Jul 23, 2009
    Thanks very much for your help Blondha.
  • 3 Answers
The temp control sensor is optional. If not connected the charger will charge at its default charge. No problem
Posted on Jul 23, 2009
I have a #20 charger inverter on my sailboat. It has worked fine for several years. This winter, I replaced the battery bank with 4 Trojan T-105. Batteries are fully charged, new battery wiring and...
Without more information, it could be a number of things. For starters, you might try disconnecting the ground wire to see if that makes any difference. The Xantrex Owner's/Installation Manual says specifically not to connect the inverter's negative *battery cable* to the vessel ground, but if the unit's housing and the negative cable share a common ground somewhere inside the unit, that would be the same thing. The T-105s are great batteries, but since they are 6V, make sure you rewired them correctly, i.e. a pair in series (12V) wired in parallel with the other pair for 450 AH total. Recheck all your battery connections and make sure you didn't blow the inline battery fuse in case you inadvertently made a momentary wrong connection during the new battery installation.
Apr 27, 2010 | Xantrex Technology Heart Freedom 30...
Inverter seems to be working but batteries aren't
is the bateries draining quikly?, if so try redusing the load on the inverter ,always make sure it is fully charged before use.
Feb 08, 2010 | Xantrex Technology Heart Freedom 25...
Freedom 20 Inverter/Charger Overload will not reset.
When I switch my Freedom inverter on it shows E02 fault Low battery voltage. I have had the batteries tested and they are okay.
When I plug into the mains to charge batteries the Chrgeheart interphase shows charging light but nothing happens No current.
If anyone could advise I would greatly appreciate it. Thanks
Ian
Dec 16, 2009 | Xantrex Technology Heart Freedom 20 12...
Heart interface 30 marine quit charging
the charge fuse may have broken or the charger is bad
Jul 15, 2009 | Xantrex Technology Heart Freedom 30...
I have a Heart Interface Freedom 20 Inverter/Battery Charger installed on a powerboat. The fan (cooling fan?) is making noise - it seems to be rubbling inside the unit. Is there a way to repair? Replace...
The fan can be replaced. It is very similar to some of the PC cooling fans. I've got the same problem (again) and will be replacing it soon. I will give you the fan specs once I remove my fan ( I think it is 4" 120VAC - will let you know when I repair mine).
Jun 14, 2009 | Xantrex Technology Heart Freedom 20 12...
Freedom 20 Inverter / Charger
1997 monoco dynasty and the invorter heart interface freedom model 20 the problem we are having is the we don't get any powere from the electric outlet and the lights don't work and there is a reading in side on wall that tells you about your electricity and it reads overload my # 817-614-7576 donna
Feb 16, 2009 | Xantrex Technology Heart Freedom 20 12...
Xantrex Technology Heart Freedom 20 12 Inverter Logo
309 people viewed this question
Top Xantrex Technology Boating Experts
Craig Butler
Craig Butler
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
