Question about Cooktops
Replacement of control board for Electrolux Icon 30''
Came home from Vacation and found that the unit had an error message and had beeped until my 30 yr old son had thrown the breaker. He waited a while and tried turning the breaker back on to no avail. I had a service man come & he diagnosed that the control module was bad. None are stocked locally (Houston, TX). Ordered and part was sent directly to me, rescheduled service man, found part broken during shipping. (Note: each of these trips requires a week). Reordered (oops! they forgot to order - resulting in 2 weeks) and once received, rescheduled service man. Service man installed, turned on the breaker and unit was no longer beeping so he left - I came home to find that yes it no longer beeped but it also did not work at all. Service man back - guesses that it is a bad module - it is ordered again. Am still waiting for this one. Should be in on Wednesday. Yes, Electrolux has covered under extended warranty but I have been without for over a month. Or there any other options for repair - it is not yet 2 years old. How can I be sure that it is a control module problem?
  • yadayada
    yadayada May 11, 2010
    go with the service man and the new control board, really dislike these new computer controlled appliences.
    President:
  • 744 Answers
Hello, I am going to go out on a limb here and risk a bad feedback score but I have seen this many times in the past few years and have even made the mistake of replacing the EOC (Electronic oven control) when the EOC was not the problem, Reading between the lines with no model number I'm going to assume you got the error code for a bad EOC which is why the repair guy changed it. Well the second one could be bad too but I seriously doubt it. To me after changing the EOC and it still don't work the problem is going to be with the touch pad if it has one (be mindfull I dont have model number so I don't know other then electrolux which oven this is). The way to test this diagnosis is to turn the power off...Remove the ribbon/cable harness from the touchpad to the EOC. Switch power back on and wait 24 hours. If Error code does not return it's the touch pad, if within the 24 hour period the error comes back it's the EOC. Can't be any easyier then that to figure which it is and any tech worth his salt would know that. Hope this helps some, Maybe you can try it while you are waiting for the new part. Good Luck!! if you have any further questions or concerns please feel free to comment again. Mike
Posted on Jul 20, 2009
Power went out. reset circuit breaker and all the lights keep flashing 8.8 and won't stop
Hello Heidi, thank you for your post!
From my understanding your Electrolux cooktop is displaying an error code of 8.8. The error code of 8.8 means there is a shift register issue on the middle touch board. This could a possible issue with the control board or the middle touch board. You may need to have a professional technician out to your home for proper diagnosis. We hope this information is helpful to your repair. -Matt
Jan 23, 2016 | Electrolux 36"" Induction Cooktop
Electralux Surface Cooktop, with code---E----40
Hi Linda Wallman, thanks for your post!
I see that your Electrolux cooktop is displaying an "E40" error code. Typically, the "E40" stands for no communications, shorted bus. This could be an internal communication error with your left control board, relay board, or filter board. I would recommend getting a technician out to your home for proper diagnosis and repair. I hope this is helpful. -Matt
Oct 20, 2014 | Electrolux Cooktops
Electrolux e21
Thank you for your post, friend!
I understand that your Electrolux cooktop is flashing an "E21" error code. Based off the information I was able to look up it sounds like a possible issue within the left board. I would suggest seeking assistance from a technician for proper repair because some of these intricate parts do require precision and patience. Therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. -Matt
Sep 28, 2014 | Electrolux 30" Induction Cooktop
Error code 32
Same unit, error 32. Replaced capacitors that were bulging on relay board. Work for a bit now same error message. Read somewhere else that they capacitors on filter board likely went as well. Where is the filter board located? I am guessing under the induction elements because I can't imagine it would be anywhere else. Can someone please assist in telling me how to access that board? I would greatly appreciate it
Dec 21, 2013 | Electrolux Cooktops
E30ic80iss electrolux error 31
Good Morning D, I am happy to assist you. Error code E31, commonly refers to an internal generator error in the left side cooking zone and that the generator control board needs replacing. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, I would recommend connecting with an experienced appliance repair tech to assist further.
Jul 30, 2013 | Electrolux E30IC80ISS Cooktop
Induction error e6
Hello it07002 - You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control) and/or user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
May 07, 2013 | Electrolux 36" Electric Hybrid Induction...
Error message on my electrolux INDUCTION STOVE TOP
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
Electrolux cooktop E14 error
Hello Winnie - Error code 14 means that there is a communication failure with the key sensor for cook place 4 (left position) - right board. Base on the intensity of the issue; contact a professional technician to diagnose the following: Test flex cable between boards, change right board, change center board (on 36" models only), change left board.
Sep 23, 2012 | Electrolux 30" Built-In Electric Cooktop -...
My electrolux iduction cook top sends error across the whole bord when I put anythng on the inductoin burner
You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by flipping the circuit breaker off and back on. If the error code does not clear, then the unit more than likely can be experiencing an issue with the EOC and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
Sep 11, 2012 | Electrolux 36" Electric Hybrid Induction...
Electrolux Induction Cooktop E36IC75FSS Error Code 41
Hi Sue -- when you switched the breaker, how long did you leave it off before switching it back on? Generally, it's a good idea to leave the breaker off (or unplug the unit) for a full 30 seconds before switching the unit back on. If you did have it off for 30 seconds and the error code came on after that point, then it may possibly be a relay isse. That will more than likely require a visit from an authorized servicer to properly diagnose the cooktop. Hopefully the 30-second test prevails and the issue is resolved. Best of luck!
Aug 27, 2012 | Electrolux 37 in. Designer Series...
Cooktops Logo
314 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
