Question about Kenmore Washing Machines
Kenmore washing machine series 90, will not agitate, spin, or drain. Door switch is good. Wigwag solenoids have continuity. Motor start capacitor good. Motor will spin if belt removed.
Water pump checked out good. Buzzing noise, not like the out-of-balance buzzer, when switched on in an agitate or spin cycle. Goes away, then returns after about 2 minutes.
  • 575 Answers
Unplug the unit. Remove the hoses on the water pump to check if it is clogged. Water will come out so be prepared. Check how you can check for error codes.
Posted on Dec 13, 2016
Kenmore 90 series heavy duty washing machine will agitate, but will not drain or spin.
check drain solenoid valve.follow drain hose into machine.valve should be lcated in this area.
Oct 16, 2009 | Kenmore Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Clicks when it agitates and does not agitate very well
Look on the wigwag solenoids. their are 4 wires a white common wire on both solenoids and 2 different wires one on each solenoid. Check each solenoid for continuity. now here is the secret. This washer is getting age on it. The solenoids have shift pins mounted on shift levers to change the action from wash to spin. the motor on this model does NOT reverse. It relys on the wigwag assembly to do the shifting. The shift pins get rusty and won't move. Remove the shift pins and sand them down so they will slide easy when the solenoids are energized. if you feel like it is something wrong with the solenoid or the time you cans witch the none white wires and it will spin instead of wash and vice versa. This washer is a good un but an old un. unless it starts leaking i would hang on to it as long as possible. Let me know if you have more questions.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 15, 2009 | Kenmore 22422 Top Load Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Kenmore 60 series will not drain
Well if this is a belt driven model then your solenoid coil is bad.
This model 's motor only revolves in one direction. To spin it has to shift gears. It does this by means of a solenoid mounted on the transmission called a wigwag. Note: if the lid switch is bad no power can go to the wigwag and shift it. If this is a direct drive model(no belt) then it has to be a bad lid switch.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
Washing Machines Logo
32 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
