Question about HP LaserJet 4650n Printer
How to fix hp laserjet 4650n memory error - HP LaserJet 4650n Printer
SOURCE: Memory Low Error
Have you tried clearing previously saved faxes. Worked for me.
Posted on Aug 18, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: low memory display on HP Laser Jet 3050
Hello All,
Please perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
Posted on Nov 03, 2008
  • 125 Answers
SOURCE: hp laserjet 4650n
Hi 123sha:
To continue
turn off then on
A critical firmware error has
occurred that caused the
processor on the formatter
to abort operation. This type
of error can be caused by
invalid print commands,
corrupt data, or invalid
operations. In some cases,
electrical noise in the cable
can corrupt data during
transmission to the printer.
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
printing a different file. If
the message appears
only with a certain
software program or
print job, contact the
software vendor for
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
DIMMs from the printer.
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
Posted on Jan 10, 2009
57 varieties
  • 1653 Answers
SOURCE: error memory 10.1000
This means that a specific cartridge has an e-label error.
The solution is to:
1. Reinstall the print cartridge.
2. Turn off and then turn on the printer.
3. If the problem is not solved, replace the cartridge.
Posted on Oct 07, 2009
  • 21 Answers
SOURCE: HP LaserJet M1522 with error 49
on you can update the firmware and that should take care of it. its a free download
Posted on Jan 07, 2010
How do I clean an HP 4650n printer
Can you be a little more specfic about what you want to clean. Outside? Inside? Do not use a regular vacuum to clean up spilled toner as it is so fine it will go right through the vacuum into the air and you will breath it in.
Aug 31, 2014 | HP LaserJet 4650n Printer
Toner on transfer belt of an hp 4650n
Toner on the belt is normal unless it is interfering with the print quality. The belt cost around 300.00
Jan 14, 2013 | HP LaserJet 4650n Printer
How do you print duplex on a HP Laser Jet 4650n
You have to print the first side then take those prints and put them back into the paper tray to print the second side (Manual Duplex). If this were a DN model it would have built in automatic duplexing and you cound select "duplex printing" from your print setup screen and the printer would print both sides automatically.
May 13, 2010 | HP LaserJet 4650 Color Printer Manual...
Hp 4650 supply memory error
This is caused by a faulty chip on a toner cartridge, possibly the one that you last installed. Replace the toner cartridge
Apr 27, 2010 | HP LaserJet 4650n Printer
I have a HP 4650n and when I print there is line through the middle of paper or picture. Replaced cartridges and fuser. Not sure what to do.
Probable : Dirty paper Xport rollers
Possible : Main molibdene shaft scratched (if line always same position)
Feb 06, 2010 | HP LaserJet 4650n Printer
When trying to print on HP 4650 printer stops and displays 49.4C06 error code, how can I fix it? thank you
update the firmware first...if problem persists try removing the jetdirect card..if error goes away your jetdirect card will need replaced
Dec 16, 2009 | HP LaserJet 4650n Printer
HP4650 suddenly printing very slow from Adobe Photoshop
Turn the printer off then back on or download a new driver from hp web site.
Jan 16, 2009 | HP LaserJet 4650n Printer
HP 4650N Will not print more than one copy of a job
make sure when printing it has all checked off in the page range box instead of pages
Aug 28, 2007 | HP LaserJet 4650n Printer
HP LaserJet 4650n Printer Logo
Ben Johnson
