Question about Crafts & Hobbies
Lionel 3656 Stock car, the doors do not open when switched. I put the car with the center over a track for my milk car the doors do open. There is one coupler near the front of the car in the track.
4 Suggested Answers
  • 13 Answers
SOURCE: I have a marklin 89 006 HO loco with freight cars
found your couplers and wheels.
http://www.eurorailhobbies.com/erh_list.asp?mn=1&sc=HO&ca=76
might have to copy and paste, enjoy :)
Posted on Mar 17, 2010
  • 38 Answers
SOURCE: Ι've just joined 2 ovals
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Posted on Jul 23, 2011
  • 747 Answers
SOURCE: I just bought a new lionel o guage remote control track section. My train can run around the oval 3 or 4 times and the uncouple button will cause a coupler to uncouple properly. Then the magnet in t
sounds like a contact issue clean all connections make sure they fit tightly when a bad connection occures it will cause metal to heat up check both sides of the circuit with an ohm meter
Posted on Sep 04, 2012
When I my brand new Lionel train on the track, the red light goes out. Is there a short in the loco?? This isa the Polar Express 73-0218-250 model Xmas is tomorrow!!
I am assuming that the throttle is off when you put the train on the track. If off, then you are correct that there is an internal short in the engine. You might try disassembling the unit and looking for a pinched wire specifically from a roller(s) (center rail pickup). You might also check for a short between a pickup roller and a wheel with a VOM. Make sure the wheel is not the one with the neoprene belt.
Dec 25, 2014 | Lionel The Polar Express Train Set
Lionel 3656 parts
see page 11 of attached pdf for operating instructions:
http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
Brasseur Electric Train's, parts for 3656:
Lionel 27 Parts
Apr 17, 2014 | Lionel Crafts & Hobbies
Wiring 1122 switches for crossover
Question is unclear. But if you want both switches to throw at the same time all you need to do is connect the 3 terminals on one switch with the matching terminals on the other switch. Run a wire from left to left, center to center and right to right. If the switches do not switch into the same track just reverse the right and left wires on one of the switches.
Nov 27, 2013 | Lionel 40 Watt Transformer Train Set Track...
Lionel manual for a #3656 cattle car
HOW CAN I GET THE SPECS FOR THE PLATFORM
Jan 24, 2012 | Toys
CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK THRU TRACK POWER - WHAT IS PROPER WAY TO HOOK UP RED AND BLACK WIRES? LIONEL FASTRACK
Track power is not recommended for this uncoupler. Use an aux fixed supply of at least 10 to 13VAC for the supply. You have to move a jumper on the bottom of the track to do this. Then there will be four wires needed. Two for the aux power (hot and common) and the other two which go to the pushbutton switch.
Note: Same goes for Lionel FasTrack Remote switches. Run the switches from a 10 to 12 VAC aux supply. There is a jumper you remove on the bottom of the switch to connect an aux supply.
Apr 27, 2011 | Lionel 12020 Fastrack Remote Uncoupling...
My 2-8-4 Locomotive stops at the right hand switch and will not reverse. It is the only train of my three that does this
This is a common problem with FasTrack Remotes and Manual switches. It is relative to where the center roller pickup is in relation to the wheels (common connection to outter track rails). Solution is to put electrical tape on the outter rail that forms a V between the turn in and the straight away. This elliminates about 1.5" of track discontinuity. It also eliminates wheel sparking that pits the surface of the outter rail. Wish I had a better solution short of taking the switch apart and doing some rewiring.
Jan 31, 2011 | Lionel Fastrack O36 Manual Right Hand...
Whenever a piece of rolling stock sits on any portion of the switch track, the solenoid begins to vibrate. This happens with all 6 of my Lionel 027 switches. How can this be stopped? I sometimes have to...
You must use insulator pins on the inside rails than come off the frog. Also make sure each track after the switch is wired with the same polarity. Keep power to center rail and ground to the same outside rail.
Nov 16, 2010 | Lionel 027 Left Hand Remote Control Switch...
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
Connect the lionel ctc lockon to the track
The lockon is for tubular O or O-27 track. Slide the large part of the clip over the bottom flange of one outer rail....straight track works best and snap the cmaller clip onto the center rail. the two small terminals are your wire connections.
Nov 23, 2009 | Toys
Crafts & Hobbies Logo
118 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
