Question about Pride Health & Beauty
Have a pride jet 3 wheelchair when the power button is pressed all the battery lights come on steady when u move the joystick u hear a single click and no movement
  • 280 Answers
Sounds like a motor problem. Do you get a flash error code that you can post for a more definitive answer. With no current flash code, you would need to go through all the components, testing with a volt meter. There is a chance you have a bad main controller if there is no flash error code on the joystick. If you have access to a hand held programmer you can read the fault codes stored in the controller. By faulting out the chair you can see which fault code increases in number of times it occurs. Start with the obvious first like load testing the batteries. Move on to checking motor lead resistances (motor/brake checks) and continuity of connections between joystick and controller. You can check controller outputs at the connectors. The Pride Mobility website has a series of good, illustrated troubleshooting manuals. Hope this helps.
Posted on Dec 14, 2016
Testimonial: "no flashing error codes after the single click"
How to reset manual brake control and where is it.lights go on( 2 red & 2 green) but jet joy stick is so touchy lights blink and I have to restart it.
If the joystick turns completely off when you try to drive it means the batteries instantly are dropping voltage below the operating capabilities. I have also seen bad connections in the battery wiring harness cause the same thing.
Sep 15, 2014 | Pride Mobility Products New Pride Mobility...
The chair is locked. I had this happen a long time ago and I needed to move the joy stick diferent directions to get it unlocked but I do not remember how. It is a Jazzy 1113.
If it is the older VSI controller, turn on chair. as the battery lights scroll, hold the joystick in the (UP) position until you hear a beep. Then immediately place the joystick in the (down) position until you hear a beep. then place the joystick in center position, once you hear the beep for the final time, it should be unlocked.
If you have a Dynamic controller, turn on chair then press the horn button to unlock.
Sep 15, 2011 | Pride Jazzy 1113 ATS Indoor Power...
When I turn on controller power the speed lights flash slowly. Joystick does nothing and chair is dead. Chair is Pride Jet 3 Ultra.
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Apr 27, 2011 | Pride Mobility Products New Pride Mobility...
ajnss I need more information. can you turn the power on at the joystick? are you getting all the lights for battery level lit? are any of the lights blinking on the joystick? do you hear a clicking noise when you try to move the chair? Give me as much info as you can thanks
Feb 05, 2011 | Pride Jazzy 1103 Ultra Standard Power...
When switched on power light flashes.
How many flashes? Count number of flashes should be a slight pause then flashes the same number of times . Your manual will give you flash codes and you can determine what the problem is. If all the lights are flashing and there is no pause the chair could be in "lockout" Your manual should tell you how to get the chair out of lockout I think that Pride uses the joystick to get it out of this mode.. Turn the chair on move the joystick forward till you hear a beep then move the joystick to the rear until you hear another beep release the joystick and the lights should quit flashing Hope this helps
Aug 12, 2010 | Pride Mobility Products New Pride Mobility...
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
Jet 3 power chair power lights just flash, no sequence of flashes
hold joystick back, press on button, move joystick forward, then let go.
Feb 17, 2010 | Jet 3 Ultra Power Chair
Lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Health & Beauty Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
