Question about Home Security
Sync my doorbell - Home Security
Doorbell doesn't work
It seems your doorbell transmitter got wet and corroded the contacts.
These push buttons are not sealed at all and thus will let rain, snow etc. eventually corrode the electronics.
Solution: Find a new push button on eBay.
Feb 26, 2013 | Desa International White Wireless Plug In...
Where can I buy a doorbell for use in potty training my dog?
Amazon sell a doorbell that your dog can be trained to ring when they need to go to the bathroom outside.
Aug 26, 2012 | Anima Pets - Others
We are installing the doorbell and here is how we have it set up: the 18 volts off transformer red wire going to transformer on doorbell, negative wire going to outside button, red wire from button going...
need more info. Doorbells do not need 2 xfrms. The red off 24 volt xfmr foes to door switch and returns on white. If you have 2 door switch one switch to front door label on doorbell and the 2nd goes to back door label. What is the brand and model number/ I'll try and walk you thru it.
Jun 21, 2017 | Heath Zenith Designer Series...
Hello I have now got 2 (two) of these units over the past 8 months and neither work----changed batteries--interchanged push button---changed main unit--nothing works----but when my neigbour across road has...
The doorbell buttons and your receiver must be on the same channel. If you will get out the directions that came with your unit, they will describe the process to go through to reset the specific "codes" for your buttons and receiver.
Jan 04, 2010 | Desa International White Wireless Plug In...
Heath Zenith 6150 wireless doorbell
Yes, there is a way to change the security code. See FAQ here:
click on "how can I change the security code."
Jan 06, 2009 | Heath Zenith SL-6136-WH Basic Solutions...
Home Security Logo
44 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
