My hose is really jammed tight on my dc hoovercannot pull it out from the top
2 Suggested Answers
  • 255 Answers
SOURCE: The top spool of thread jams tight when I pull the
It sounds like the tension setting is too tight. The tension mechanism consists of two metal disks; the thread runs between these disks. When the pressure foot is down, the disks come together, trapping the thread between them. When the pressure foot is up, the disks separate and the thread can flow freely. (BTW, this is why you adjust the tension with the pressure foot down.)
Take a look at your tension setting and try loosening it. That should resolve the problem.
Let me know if this helps, ok?
Robbie
Posted on Jan 27, 2010
How do you get the extension off then its raised all the way to the top?
Hi there, it's Jack at Dyson.
DC25's instant-release hose and wand are designed to detach quickly and easily when you need them. There are no fiddly clips or buttons to press - when you extend the wand upwards to it's fullest extend and pull it firmly, it should separate from the main body of the vacuum:
If the wand seems jammed, or you continue to have difficulty removing it, our experts are on hand to take some further details and provide assistance. You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 16, 2015 | Dyson Dc 25 Animal
Have a Kenmore 80 series that has been leaking for several days now! Before I pull it out of tight space, what should I been looking for?
Check the water hoses first to make sure they are tight, check both ends of both hoses. if they are loose you can usually tighten them up and stop the water from leaking and may not have to pull it out. Although you might have to pull it out a little to get to the hoses. Also you didnt state if the machine leaks when it is operated or all of the time.
Mar 13, 2011 | Kenmore 24032\24036 Top Load Washer
Where does the fuel line connect to the gas tank?
Dont really understand the question, however the fuel hose is just a tight fit in the top of the tank, it can, with some force be pulled out, it is more difficult to replace it, to do this you have to cut the end of the hose at a steep angle, pust the now sharp end into the top of the tank, grab the other end with a pair of long nose pliers through the fuel tank filler hole.
Mar 01, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Is there an easier way to install the fuelline on my chainsaw?
It realy depends on what mahine it is and wheather it has a moulded hose or a straight hose, and what diameter the hose is, i have made a simple tool for straight hoses from a thin strand of piano wire,sharpen the end to a point, bent the end ( approx 2 mm ) over and back on itself tightly 180 degrees, make sure it is as tight as possible, connect a handle to the other end, now insert the hooked end through the fuel pipe hole in the top of the tank and out through the fuel filler hole, now connect the fuel hose onto the hook, pull it so the sharpened end makes a hole in the tube, now pull the wire back through, and with a bit of practice the hose should pull through, do not forget the trim the end of the hose where the hole was made.
Jan 20, 2011 | Garden
Robbie
Jan 27, 2010 | Janome Sewing Machines
Washer less than a year old. Top loading. Will
Have you moved recently, or moved the washer for any reason?
Two things can usually cause that.
First, Some part of the drain hose must always be higher than the highest possible water level in the machine. Remember that water flows downhill. If all the hose is lower then the highest possible water level the machine can never fill since water will drain out hose. So, raise the hose higher than the flat top of the washer and try again.
2A, Inserting the drain hose too far into the house drain. or 2B, sealing out ALL air in the drain line by using a hose too tight in the drain pipe or taping the drain pipe tightly with the drain hose in it can both create a vacuum in the drain line which will actually **** out all the water in the tub. This can be tested by pulling the drain all the way out and aiming it into the tub as you try it. Good Luck.
Aug 23, 2009 | Maytag Washing Machines
Bosch nail gun jamming and i cant get the nail out.
Sounds like the quickest way is to take the nose off. Remove The bottom 4 bolts. Pull back the nail pusher first and latch, so the magazine spring do go flying.
Once you have the nose off, then you can put in a vise and pound thru the other way.
Thanks,
Jeff
Jun 20, 2009 | Stanley Bostitch F21PL Nailer
Top radiator hose
you may have a bad thermostat . i would start there .try flashing the motor with a garden hose ok have a nice day
Mar 29, 2009 | 2001 Chevrolet Venture
Frigidair Top loader washer wont drain, but pump is running...
firs get a shop vac and drain the water from the drain hose if you don't have one get a radiator hose clamp from auto zone then remove two bottom screws from washer bottom and pull down on panel you will see a hose coming down from the tub if you didn't have a vac clamp the hose here with the clamp about mid way the pull the hose from the drain pump and check it for jamming there is no filter
Feb 12, 2009 | Frigidaire FEX831CS Top Load Stacked...
Water leak at filter
You probably will have to replace the water filter housing that holds the water filter. This is an relatively easy job and should only take about 30 min. The housing will cost around $40-$50 online or from your appliance store. Turn off the water to the fridge. Take the top shelf out of the fridge to access the water filter area. There is a small screw in a really deep hole on the bottom of the cover, just to the right of the filter cup. I used a really small socket (9/32",1/4" or 9mm - can't remember) and extention. Take out the screw which will uncover the housing. The water hoses (white) just slip onto the housing - check these to verify if they are on tight. If they are loose this is the water leak. if they are on tight (which I'm sure they are) then proceed. Take off the filter cup which is screwed onto the housing. Remember "righty tighty - lefty loosy". Take another small screw (maybe two) out which holds the housing to the refrigerator. Now pull the water hoses off the housing. This is kinda tuff because the hoses are just slid on to the housing and are held on by friction only and its hard to get a good grasp because of the location of the unit. You can't really stick much under the hoses to pry them off either because if you damage them, they won't hold the seal later. Just pull and twist and they should come off. Visually inspect the housing unit, you should be able to see a crack if there is one. Replace if necessary. Just make sure not to overtighten the screws and especially the filter cup when reinstalling. Good luck and I hope this helps.
Sep 19, 2008 | Frigidaire FRS23R4A Side by Side...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
