Question about Asko Dishwashers
Hello, my Asko D3122 has a light flashing - how do I reset this machine?
5 Suggested Answers
SOURCE: asko d/w d3122 Hi gang the overfilling
Have a look to make sure that the pump and drain hose are unblocked. If they are, you might have to call Asko and arrange a service call.
Posted on Oct 08, 2008
  • 28 Answers
SOURCE: ASKO D3122 PUMP STAYS ON AND MACHINE WILL NOT SWITCH ON
The machine has activated a safty seq. There is most likely water on the lower buttom. Leakage or drain pipe blocked. The power will get to the drain pump, when this happends. To prevent overflow on your kitchen floor. Dry out the water. Then it will start as usual.
Posted on Jul 27, 2009
SOURCE: Hi, we have an Asko D3122 dish washer, pump runs
Did you ever find out what the problem was?
Posted on Mar 10, 2012
  • 4 Answers
SOURCE: The pump on our Asko
The overflow capture plate is flooded. Basically, any overflow falls to the bottom of the unit to protect the floor. There's a foam floater attached to a lever which floats up and triggers a switch sending F2 error. Best to open bottom front skirt and sponge up any water still in the spill sump, or remove back panel to better access the water and sponge it up. F2 error message vanishes once float drops and machine starts working correctly again. Remember to fix cause of flooding, which is usually are blocked sink drain pipe. This blockage causes sink water to flow into the machine instead of down the drain.
Posted on Apr 09, 2015
Asko D3122 WAX MOTOR
Can plug in either way. If was meant only one way, the plug would have a blocking protrusion on one side. Plus the motor will run only one direction no matter which side is the hot side of the wires. As long as is getting power, it will work.
Nov 11, 2014 | Asko D3122XLSS Stainless Steel Dishwasher
Asko Dishwasher D3122 fills with water and stops
if the heating element has failed the water temperature will not reach the trigering threshold to allow the timer to advance to the next program step good luck !
Dec 26, 2013 | Asko Dishwashers
Not cleaning upper rack
Perhaps a repair service that can actually see it might have a suggestion .
Aug 03, 2017 | Asko Dishwashers
Dishwasher asko 1895 the pump the working the lights are flashing but the machine is not working
The lights flashing is telling that there is a fault in the dishwasher.
I am assuming you have emptied the dishwasher after the drain cycle failed to work due to the pipe block.
You will have to make a fresh start. Empty the dishwasher, turn the power mains switch off and on to reset the dishwasher.
Start a new cycle and see if flashing lights stop flashing. If still same problem you will have to note which light(s) are flashing and send a post on this page. There is a chance the impeller in the drain pump may have sufferred some damage due to drain block depending on how long the motor operated before you found the problem with the drain.
Jan 04, 2013 | Asko 24 in. 1895 Built-in Dishwasher
Asko D1996 lights flashing washer won't start
I'm having the same issues. What did you do to solve yours? My start button never lights up! Thanks for your help!
Oct 01, 2009 | Asko D1776 Stainless Steel Built-in...
Jul 25, 2009 | Asko D3122XLSS Stainless Steel Dishwasher
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
Asko d/w d3122 Hi gang the overfilling protection has been activated, what can I do to remedy the sitution. regards banger35
Oct 08, 2008 | Asko Dishwashers
Dishwashers Logo
244 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
