Question about Garden
Plow dont go on no light on. - Garden
  • 1 more comment
  • David Ellis Rhea Dec 13, 2016
    Hi James Cinquegrana, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please share the year, make, and model of your vehicle.
  • James Cinquegrana
    James Cinquegrana Dec 13, 2016
    20005 gmc mimet mount
  • Anonymous Dec 13, 2016
    work fine last year put on now nothing
Hand control red lite blinks and plow dont work;; this seems to be a intermitten problem usually when i first start vehicle to do plowing
Sadly FIXYA does not know every make , model of plow controller made in the world . try a local dealer of your make .I would suspect it might be a dirty connecter between vehicle and plow
Dec 25, 2017 | Cars & Trucks
Beast way to wire up plow lights on a 2008 dodge Dakota sxt 3.7 v6 4x4
Trying To Wire Plow Lights Without A Harness - Snow Plow Forum ...
www.snowplowforums.com/...lighting-wiring/13714-trying-wire-plow-li...
Oct 11, 2006 - 25 posts - ‎8 authors
They both work when I hook up the battery charger to them. ... This way,the plow lights only come on when the plow is plugged in,and ... A relay equivalent to Napa part #AR272 is good, if you give the number at Advance or Autozone they can cross reference it. 92 Dodge Dakota - 7'6" Snoway MT with DP ...Missing: 2008
Meyer Snowplow Install - Part 2 (Electrical) - YouTube
? 10:01
https://www.youtube.com/watch?v=5RSFqO80cLM
May 20, 2009 - Uploaded by CentralPartsWarehse
A real plow install taking place in our on-site, full service shop. In this video we'll show a complete snowplow install taking place on a 2009 ... How much does a complete set up like this cost? ...BEST SNOW PLOWING VIDEO!
Light Wiring for Meyer Plow - DODGE RAM FORUM - Ram Forum
Dec 13, 2015 | Dodge Cars & Trucks
On my boos plow lights the shield over the low eam light comes loose and breaks the bulb. this has happened three times on the right side and once on the left
try putting them back with a dot of silicone caulk in the corners (dont seal the entire thing) i had a snowmachine that was allways loosing its headlamp and i did this , never came out again
Feb 25, 2015 | Boss V-XT Poly Snow Plow
Meyer plow troubleshooting
Number one the plow headlights should be seperate from the vehicle. Get a new harness for the plow on ebay for cheap and have it installed. In the long run it will be cheaper.
Mar 11, 2017 | Cars & Trucks
No lights on plow, Bulbs are good!! When I turn on lights, high beam indacator comes on. If plow is unpluged, truck lights on, just fine, then when plug into plow, lights on truck go out as th
Check your grounds on the plow wiring,disconnect and reconnect the battery if the tipm reads too high a draw it will shut them down to protect the circut.Battery disconnect resets the tipm.
Dec 20, 2012 | 2001 Dodge Ram 2500 Truck
On my 1997 gmc truck when plow light switch is turned on one truck headlight goes out and plow light on that side comes on but other truck headlight stays on and that plow light does not come on..
This is just an idea, I may be wrong but any input is helpful, right? I would think that the switch that controls the plow lights is designed to alternate between the circuits for the truck light and the plow light. If the trucks headlight switch is turned on then the circuit is closed and turnes on the light. When the plow light switch is turned on it may cut the hot side of the circuit going to the headlight and engage the hot wire to the plow light. The headlight and plow light may share a common ground. If they don't share a common ground then the plow switch may cut the ground wire opening the circuit. If you can't find a solution you can always wire the plow lights directly to the battery with the same switch or a new toggle switch and then turn on the parking lights only on the truck. On most GM cars and trucks there is a space in the fuse pannel that is for a power accesory. It is basically a fuse slot that is empty labeled ACC. This is a 12V hot power source and you would run the positive wire here then ground the neg to the chassis. This way if you forget to shut off the toggle it will cut the hot when the key is shut off. When running the wire it is near the hood release able and you may be able to run the wire thru there and not drill a new hole. I've done this for neon lights under cars as well as stereo systems requiring an amplifier. If you drill a new hole even though its under the hood I would put a little blue RTV silicone over the new hole to prevent moisture from getting past the fire wall or road salt.
Oct 16, 2010 | 1997 GMC Sierra K2500
Lights on a fisher xtreme plow wont work
I'm guessing that you have already checked to make sure there is power going to the plow lights. If not use a test light and make sure. The most likely problem is the grounds from the plow lights themselves to the frame. Take the lights apart and check and/or replace the grounds, wires inside the case take a lot of vibration and that can cause them to fail.Don't forget to check the bulbs to be sure they're good too. Hope this helps.
Dec 17, 2009 | 2007 GMC Sierra 2500HD
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
