Question about Vizio Televison & Video
Vizio smart tv has no picture black only, sometimes has sound
  • yadayada
    yadayada Dec 13, 2016
    Just Google this, "Vizio LED TV has no picture, intermittent sound"
MLFnet
  • 328 Answers
SOURCE: Vizio plasma. screen went black, and the power light went out.
Sounds like the power suply went. I don't know that model off the top of my head, but you might find a replacement here http://www.electronica-usa.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=EU&Category_Code=PLA
-=/ Daft Tech /=-
Posted on Oct 26, 2009
  • 8457 Answers
SOURCE: Vizio P50HDTV10A TV went pop now has a black picture
Don't know which boards Z or Y have dead capacitors pop open,take ur tv aparts check boards that have pop opens parts or burn marks on them.Replaced that board will solved ur problems.Tries Shopjimmy.com,Ebay.com to buy refurbish boards for the replacement.
Posted on Mar 22, 2010
SOURCE: Picture but no sound on my Vizio L37 Flat Screen
I had the same thing just happen and I used the following instructions from the Vizio Website for "humming sound" on tv and it worked. My sound is now working!!!!
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on.
Reset the TV settings.
Posted on Dec 15, 2010
SOURCE: Vizio 42" tv has no picture but sound. What is
the problem is in your 42 tv bec.of your dirt tv ok
Posted on Apr 10, 2011
blueextc3221
  • 15935 Answers
SOURCE: vizio vo47L 47" LCD. No
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
More specifically on #1 and #2 - capacitors either bulging, leaking, or exploded.
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!@#$
Posted on May 27, 2011
How do I fix a 55" Vizio smart TV
Fuses but try one of those neiborhood fixers their cheaper for that piece
Mar 20, 2016 | Vizio 55" Class LED 1080p 120Hz HDTV,2.49"...
What component or components need to be replaced to fix the tv?
Try replacing the inverter board which powers the backlights on set.
Mar 18, 2016 | VIZIO P702ui B3 70 Inch Ultra Smart
My 70" Vizio smart TV will turn on but there is no picture or sound. I think it blew a fuse.. how do I fix it??
the first thing i would do id completely disconnect power to vizio tv and wait roughly two mins before plugging it back it. once that is done try to see if your picture comes back up . if your screen does not comes back the tv has unfortunately taken a turn for the worst. sometimes it costs more to repair than it does to replace so just make sure that your tv is or is not covered under a manufacturers warranty that may be able to have to tv replace for free depending on the scenario. below is the number and hours of operation. i also gave you a link to their support site. good luck!
Thank you for visiting VIZIO Support Hours: Monday - Friday 7 a.m. - 9 p.m. CST
Sat & Sun 9 a.m. - 6 p.m.
Toll-Free Number: 855-833-3221 Official VIZIO Support
Nov 04, 2015 | Vizio Televison & Video
I have a 55 Vizio 3D smart tv. This picture color fade in and out to the point that I cannot watch tv. I this a problem with the main board?
Hello Patricia,
  • There is a loose soldering connection in the Main Board. That happens because the components on the are generating a lot of heat therefore melting solder connections.
  • Stop beating on the TV's back, that only makes the problem worse.
  • Take it to a shop.Or if you are a tech, try locating the loose connection(s) and solder it back.
  • Also check your Warranty Period, It may cost you 0$. Call Vizio if you still have Warranty on the TV.
Here is a link to Vzio Supoport.
Good Luck,
JP
VIZIO Product Support and Services VIZIO
Jun 25, 2015 | Vizio M3D550KD 55 inch Class Razor LED...
We have a 70inch vizio smart tv we have sound but the picture went out
Likely a failed power supply.
Checking for certain failed components requires some technical knowledge.
Dec 20, 2014 | Vizio E701I-A3 70-inch LED-backlit LCD TV...
47" Vizio LCD Smart TV, left half of picture is black & other half works fine. Sound works fine.
when i start tv 1minit picture show 1minit after no picture but sound have
Nov 18, 2013 | Televison & Video
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
My Vizio p50hdtv herd spark, and TV went black, no picture no sound
Check and replace the main power regulator board as card basis. It has damaged.
Oct 11, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
