Question about Hoover Washing Machines
Hi; I got Hoover HDB642N it is stop and not working suddenly ..I check the power socket ,fuse and the power going to the main board is ok but no output from main board.is that mean main board fault
    Top Expert:
  • Hoover Master
  • 80,637 Answers
I would suspect the main board has failed.
Posted on Dec 13, 2016
Testimonial: "is it applicable to change it. and where can i find the program of this washer."
Washing machine just stopped working.
Hi,it could be the programe board,or could just be the starter switch,just food for thought all the best hope you sort it.
Nov 26, 2015 | Washing Machines
My MW511 won't start
Check the input power is coming or not. Check fuse inside control board & wiring too. If everything ok then it's problem of control board
Oct 14, 2017 | Washing Machines
My Toshiba TDP-S8 projector will not power up at all.
hi,
check the mains chord, also check the power in the wall socket to which the projector is connected. if all these ok then,may be its power supply side have some problem. its an smps power supply. just check its input fuse on the smps. if it fond faulty the do not replace it suddenly. check is there is any thing faulty on the smps board. because the fuse will blow off only if there is any problem in smps. check it first before inserting fuse.
ok
Dec 21, 2010 | Toshiba TDP-S8 Multimedia Projector
Sudden power input failure, fuse in plug OK power socket live. No preceeding problems with set. HELP!!!
Bad caps in your high voltage section around the 3 main transformers check them all don't skip one if one reads short pull one end out the circuit board and check it again. Most likely this is your problem
Aug 05, 2010 | LG RZ-20LA70 20 in. LCD Television
No power at all
im guessing you have opened up the case of the amplifer
look in the area where the ac plug plugs into the box.
you may have to remove some of the boards to get to it
the main internal fuse should be next to the place where you attach the ac plug
also check the main wire wires that go into the main board from the power supply check for voltage
May 11, 2010 | NAD C370 2-Channel Amplifier
TOTALLY DEAD
CHECK THE FUSE ON CONTROLL BOARD, CHECK THE CONTINUITY OF THE LOW VOLTAGE TRANSFORMER.
May 02, 2009 | Microwave Ovens
Hotpoint WD64 No power - help please !
hi from n/west uk from the symptoms you describe ? that you have no lights on machine? this is most definately total power loss to machine so if you are certain? the fuse is ok? next is has the wire/lead from plug chaffed or damaged breaking the supply? this next possibility may sound odd but the socket you plug machine into ? may be faulty ie the damp location at rear of machine could have caused deteriation of socket terminals or wires even the wire may have broken/come loose? have had this happen in homes and caused by wires not secured properly and eventually arcing/ resulting in power fail at socket ? may i suggest try another elec appliance ie lamp/hoover/ iron? to check if socket is operating just to eliminate? also if the socket is a fused type? make sure this fuse is ok too? finally have you checked consumer unit for possible seperately fused/trip out for the machine use socket ? hope this helps find fault best wishes
Oct 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Ricoh 1027 copier no powew at all
The problem may be one of the internal fuses. Whip the side panels off (with the machine unplugged of course) and check the fuses on the power supply boards.
Feb 18, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Yamaha RX-V461 receiver audio
Disconnect the unit from the mains at the wall socket. Leave powered down for 5 mins to ensure a good reset and turn unit on again and see what happens. If there is still no life. Check for failed fuses inside amp. ALWAYS RELACE FUSES WITH THE SAME RATING AND TYPE.
Dec 15, 2007 | Audio Players & Recorders
Washing Machines Logo
29 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
