Question about Sharp Televison & Video
Sharp how to fix light - Sharp Televison & Video
How to fix it?
Contact Sharp, there are no aftermarket parts for that unit yet.
Oct 10, 2016 | Sharp Refrigerators
Sharp lg-32bx6m, contrast light is not enough, how can i fix this problem
Select menu, display settings, select brightness/contrast/sharpness etc. and adjust these to your likings.
Jul 27, 2012 | Sharp LC32BX6M TV
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Photocopier 2114 makes all black copies
OPEN top cover make a copy see if copy exposure lamp turns on or not
May 25, 2010 | Sharp AR-5320 Black and White Copier
Sharp LCD flashing red light and no picture
yes thats is a common problem for all flat tv not only
sharp ;/ first theres is capacitor in power supply
you probly have few one there blow up and it could bee from the power section of your back light circuit
a good technician can fix that easy
good luck
Apr 02, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
My Sharp Aquos is buzzing. How do I fix it all of
you might have a red white or yellow cord in the wrong slot thats what was wrong with mine and just switch them around and there was fine
Jan 22, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
Oct 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos lc42d62u green blinking light
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.
Feb 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No picture, but power is on...
How many times does the POWER led blink per sec? (dont worry about the OPC)
2x = power supply (not as expensive to fix)
3x = Main board (expensive to fix)
Oct 20, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
21 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
