Question about Garden
WESTERN SNOW PLOW WILL NOT GO DOEN STOPS 2IN FROM THE GROUND
  • 89 Answers
SOURCE: western snow plow will only angle to the right .
IVE NEVER WORKED ON A SNOWPLOW BUT NOONE ELSE IS OFFERING ANY HELP. IT SOUNDS LIKE FLUID IS LEAKING BY THE VALVE AND PRESSURIZING THE LEFT SIDE ALL THE TIME. IT ALSO COULD BE YOUR NO-SPILL COUPLERS CLOGGED OR NOT OPENING FULLY PREVENTING FLOW OF FLUID ON THE LEFT SIDE. GOOD LUCK. JODY
Posted on Apr 07, 2009
redbeard00
  • 957 Answers
SOURCE: Can I make a 99 Chevy 1/2 ton Western Unimount
No. it is technically possible but there is a good amount of metal fabrication involved.
Posted on Apr 28, 2009
  • 832 Answers
SOURCE: western snow plow when you try to angle to right
This is a control valve problem. From you comment, it is
clear that the control valve flows to one direction only.
Please check the control valve of the snow plow that
execute the angle to right or angle to left. Also check
the pipelines before and after the valve. It must have a
free flow of the fluid.
Posted on Dec 02, 2009
mickey813
  • 472 Answers
SOURCE: riding mower snow plow
go to manuals online put in model number off the snow plow and it will show you the manual
Posted on Feb 12, 2010
  • 55 Answers
SOURCE: 2006 snow bear plow,
Yes, Check where strap or chain is mounted to winch. It could be loose or have dirt or oil on it something to make it slip.On mine there's a brass piece that raps around the shaft, It got lose and dirty so I cleaned and tightened it. If you pull motor off winch to check gears [don't use gear] when reassembling it's too thick when it's cold. I used white spray lube. Hope it helps!
Posted on Jan 22, 2011
Plow lights work OK, but why is there no power to joystick?
Bad connection in plug,bad wire, fuse or fusible link, faulty joystick.
press the helpful button and check link below
western plow problem Snow Plow Forum Let Talk Snow Discussion Forums
Jan 14, 2016 | 2002 Ford F-150
While driving down road my western snow plow is rocking all over.
not good or safe! check all mounting pins and frame mounts. A lot of force is on snow plows and the frame mounts often need to be welded up. I imagine it is the whole unit and not just the plow.
Mar 12, 2015 | Cars & Trucks
Western plows
Needs bleeding,got air in the line.
Dec 09, 2013 | Cars & Trucks
NO power wont lift
boss plow will not go up or down, do not have light on main control. Truck lights will go on but when toggle switch is activated, truck lights stay on and plow lights will not go on.
Jan 28, 2011 | 82" TruckSUV Snow Plow
My snow plow keeps lowering to the ground after i
You have a hydraulic valve leaking in the pump.
Jan 28, 2010 | 1991 Chevrolet S-10 Blazer
Western snow plow when you try to angle to right it goes up does same thing if you try to angle left
Oct 30, 2009 | Plumbing
Wiring for western plow joystick
My western snow plow will not go up or left or right with joystick. I can use a screw driver and make contact on the silanoid and then move the cables with the joy stick and then it will work. I have relaced selinoid and contacts. any ideas? Stomped
Oct 25, 2009 | 1990 Chevrolet Crew Cab
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
