True balance l g washing machine. Miele. What does red key with line across it mean on the estimated time remaining screen mean?
    Genius:
  • 1,181 Answers
Miele W1926. The red light over the faucet icon is on at the end of the cycle and the final spin cycle doesn't go on.
Check the screen filter where the cold water line attaches to the machine. Clean both hot and cold.
May 02, 2015 | Miele W1926A Front Load Washer
Our miele w911 washing machine keeps stopping in the main wash cycle - red light above the tap symbol. What does it mean?
check that the water flow solenoid is operational and not blocking of the spray rinse requriement
Mar 23, 2015 | Miele Washing Machines
What does this symbol mean
This normally means the that it has locked the door to stop an children opening it while it is washing. If it did not lock the door, a child could open it and burn themselves on the hot water.
Dec 20, 2013 | Miele Washing Machines
Miele W830
Yes your diagnosis is correct. We had the same on a machine that had done 12,400 washes on a life expectancy of 8,000 washes. Great machines. Airport lounge washing dozens and dozens of towels every day, 7 days a week.
Our machine had a sensor that doesn't let the machine spin at full speed if the drum is out of balance. It was something like a WS3120. We swapped it out for a much larger Miele.
Dec 04, 2017 | Miele Novotronic Premier 500 Front Load...
My machine stopped and made a constant beeping while the 3rd, 5th, 7th & 8th lights across the top remained on. What does this mean????
It sounds like this is a Fisher and Paykel-made top load washing machine and you are referring to the Wash Progress LEDs. The flashing of the 3rd, 5th, 7th and 8th LEDs from left to right indicates fault code 43 and it means the Motor Controller Module has detected that the out of balance switch is permanently tripped. The out of balance switch lever may have been stuck in the open position or the harness connecting it and the Motor Controller Module is disconnected.
Move the basket assembly as far as it can go towards the right hand rear corner of the cabinet several times to possibly lodge the lever back into close position. Raise the top cover then locate the out of balance switch at the right hand corner of the cabinet then make sure the lever is hanging freely. Disconnect the out of balance switch wire harness, if the lever is properly hanging but the same LEDs are still flashing (Fault Code 43), then join the terminals together to bypass the switch.
Reconnect power then start the machine. Replace the out of balance (OOB) switch if the machine works fine with the switch bypassed. If not, check the continuity of the OOB switch wire harness and make sure it is snugly connected to the Motor Controller Module. The problem is in the Motor Controller Module if the wire harness is intact and snugly connected but the machine still doesn't work even with the OOB swicth bypassed. Replace the Motor Controller Module if that is the case.
Mar 22, 2011 | Washing Machines
The digital timer on the machine will say 1 minute to go, but the machine will run on the spin cycle for 6 to 8 minutes before it finishes. Is there a part I can replace to correct this problem?
Your washer displays an estimate of time remaining in the current wash cycle. That estimate is based on the load finishing without any delays. Prior to going into a high speed spin, your washer "tests" the load balance by either rocking or slowing rotating.
If it senses and off balance condition, it will attempt to "rebalance" the load by itself and then retest, rebalance, etc. until it is satisfied that the load is as balanced as possible. Then it begins to spin. When your washer takes longer than is predicted in the display, it is because of this.
Happy washing...
Jan 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
May 21, 2010 | Miele W865 Front Load Washer
Check Inlet
where the water lines attach to the washer at the back un screw them and check the screens on the water valves see if rust or trash is restricting the water flow
May 24, 2008 | Miele Novotronic W1918A Front Load Washer
Washing Machines Logo
234 people viewed this question
Top Washing Machines Experts
