Only the central speaker is not working when i am playing music from external source . Although the speaker and connecting wire is fine . What could be the reason ?
    Top Expert:
  • Computers & ... Master
  • 26,210 Answers
Make, model and OS of laptop please.
Posted on Dec 14, 2016
3 Suggested Answers
  • 1584 Answers
SOURCE: IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Posted on Dec 22, 2009
mav3rick
  • 47 Answers
SOURCE: my internal speakers have stopped
remove the sound drivers then install the latest drivers
2. check if the corret sound out put is selected in sound option in control manger
Posted on Oct 15, 2010
How do I make sure that my Pioneer in-dash is working before installation
If you have access to a car battery charger or other 12 volt battery source, you can twist the 12 volt memory and accessory wires together (yellow and red) and attach those to the positive voltage source. Connect the ground wire (black) to the negative source. This will allow you to turn on the unit. Now, you need to have a sound source, and at least one small speaker to test with. Use a CD (simplest) or USB stick with music, or bluetooth enabled phone, whichever will work with your radio to provide music. If you have a bookshelf stereo speaker, or even an old speaker from an alarm clock that should work fine. With your radio powered on, music playing, volume turned up to a moderate level, touch each of the radio's 4 speaker channel's wires to your speaker and make sure you hear sound. If you don't have a car battery charger handy, you can also use an electric drill battery but be sure you know which battery terminal is positive and which is negative before you connect your radio. Another source of 12 volt power may be any number of power adapters that plug into an AC outlet, but you will need to proceed with caution. Check the back of the outlet and note the DV power output, as well as the current output (measured in amperes, or denoted with "mA" or "A". You will need a few amps (not milliamps) to turn on the radio, and at least 12 volts. You'll have to cut and strip the wires, so it's important to know which is positive and which is negative before connecting your radio to the wires. Again, please exercise extreme caution. Do not short the wires together or connect them to your radio in reverse once the adapter is plugged in. Do not perform ANY wire work while the adapter is plugged into the wall.
Jan 06, 2018 | Pioneer Computers & Internet
No sound from speaker but through ear piece I get sound.
Many devices will automatically switch off the large speaker when ear phones are plugged into them. Also there may be a switch or button or prompt on your radio to switch between regular speaker and ear phone jack. Look for that first.
Try connecting and disconnection ear phones while listening to a station and see if the problem is intermittent. If is works sometimes but not every time then it is most likely an internal connection.
You will have to access the inside of the radio to investigate further. Connect a working external music or sound source with speaker wire to the terminals inside the radio that connect to the radio's speaker. If the radio's speaker works with the external sound source then you know it is a bad connection inside your radio. If the radio's speaker does not work with the external sound source then it is most likely a faulty radio speaker. Look closely for a broken solder point or broken/disconnected wire.
Sep 10, 2013 | Eton E100 SW/FM/AM Radio
One speaker stopped playing bass
Sound like either the crossover or the driver has blown or, if you're lucky there is a loose connection internally if you have only checked external connections.
Jun 01, 2013 | Mackie MR5 MR5 Reference Monitor
All everything i play dont have sounds.like music,video
what laptop model do u need drivers? if not. download VLC from filehippo.com it will play all media music and everythign
Mar 23, 2011 | Computers & Internet
Wiring internal board of labtec computer speakers
The shielded wires are for ground, so they get connected together. Plug the wire into the PC and run some music. Then touch each wire to the others. You only have a couple of combinations to try...red-to-green and white-to-yellow, or red-to-yellow and white-to-green, . You can do this while the PC is one and music playing until you get sound thru the speakers. There virtually no current running thru the wires and you can't hurt the PC by doing this.
If the speakers use an external power supply, have it plugged in and working when trying these connection options.
Sep 07, 2009 | Labtec LCS 1040 Computer Speakers
Samsung HT-X50 DVD Audio Problem
I had this same problem and checked all of my cables and wires. Come to find out one of the wires that connected to the central audio speaker (the one that the audio track comes from) was unplugged. I plugged it in and that fixed it! My audio track is back! So make sure that all of the speaker cables are properly connected! That might be the source of your troubles!
Apr 19, 2009 | Samsung HT-X50 System
No sign of life in external notebook speakers
  1. If the powerlight is turning on some times and off sometimes, Then it may be a problem with the powersupply connected to the speakers. Check it.
  2. If the speakers are on and are not playing, Then try playing some music through alternate source like ipod,walkman etc.If the speakers are playing with alternate music source, The try reinstalling the audio drivers of your note book.
  3. If not then your speakers might have fried up due to some reason.
Feb 01, 2009 | Audio Players & Recorders
ALCATEL 4028/4029 PHONE. WOULD LIKE TO KNOW IF IT PLAYS MUSIC SO I CAN HEAR IT WHILE I WORK?
Depends which Alcatel system the 4028/4029 is connected to.
If OXO, you will require an external music source to be connected to the AUDIO-IN port on the CPU (RJ45 plug using pins 1&2) and is recommended to install MOH/Paging isolating transformer. To enable background music on 4028/4029, hold the green speaker key for several seconds. Starts flashing and the volume can be adjusted with the + & - beside the mute key. To disable, just repeat hold process.
If OXE, will require engineer to program softkey & again will require an external music source...
Good luck...
Sep 03, 2008 | Alcatel Lands Phones
The 2nd speaker doesn't work
will try and troubleshoot, mine does the same
Jan 30, 2007 | Roland MA 8 Computer Speakers
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
