Washing machine just turns on drain pump locks the front door and does nothing, lavamat 74620 . Is it the main control board
2 Suggested Answers
  • 5 Answers
SOURCE: Lavamat 74620 pumps out and does nothing no error codes? Door locks drain pump does nothing and no water fils motor does not spin. Is it the main control board? Brushes look ok on motor fan belt ok
Have you checked for anthing that has gone into the drain filter, there should be access to the filter via a small access way at the front of the machine either left or rihgt side at the bottom. Your instructon manual would give directions on how to access the filter location to check the filter is clean and should be checked regularly to keep your machine running correctly.
Posted on Dec 13, 2016
Testimonial: "Anyone have a trouble shooting manual lavamat 74620"
Dec 13, 2016 | Washing Machines
I need to replace the water pump og AEG Lavamat 74620 (1998)
So do it. there are two. one to recycle and one to exhaust. they are close to each other in the front bottom left hand corner of the casing below the drum and behind the lower front panel that contains the filter and drain. though it's far easier to get at them by removing the thing from situ and taking the back off.
Mar 18, 2013 | AEG Washing Machines
Replace pump in aeg 74620
Remove the front panel. usually requires top off. powder tray out. and front lower drain/filter panel off. and then you can get to front panel screws front panel will still be attached by door seal sometimes there's enough movement to still get to pumps without removing it otherwise if you think you can get it back on remove that from the door lip and remove the front panel. the pumps are at the bottom left near where the pump filter door was. remove the relevant one. the recycler is attached to the pipe that goes straight back up to the top of the drum. the other is attached to the outlet pipe which heads off to the back of the cabinet
Mar 18, 2013 | AEG Lavamat 72640 Front Load Washer
Aeg lavamat error 40e
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board.
Feb 04, 2011 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 74620 shows a Cd error code. Can you tell me what problem this indicates.
CD means door lock is defective. this may be due to the door catch broken or even the main board being defective.
Nov 23, 2010 | AEG Washing Machines
The machine wont spin or agitate
does the unit drain ? If not you can use a wet dry shop vac attach it to the end of the drain hose and remove the water. Then check the hose that lead to the drain pump and make sure there is nothing stopping the flow of water.
there are two other thing that may need to be replaced if the drain pump is not obstructed they are the door lock or the main control board
Sep 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Making humming noise power not on door locked
turn off the unit.use a wet dry shop vac and attach it to the end of the drain hose this will remove all the water then you can turn it back on and should be able to open the door to get your clothes out.
after all thatis done you need to check the drain pump and make sure there is nothing blocking the pump.other likely problems are the door lock mechanism is bad or the main control board
Jul 05, 2010 | GE Energy Star WCVH6260F Front Load Washer
AEG OKO_LAVAMAT 74620 gave me a code error C7. What is it?
take off the bottom front panel, a booklet is taped to the right side of the panel for the sevice tech it has all the codes
Feb 28, 2009 | AEG Lavamat 72640 Front Load Washer
AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Aug 27, 2007 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
