Question about Plumbing
My fp2212-12 submersible 2 wire pump, only makes a humming noise and wont the pump any water to the house, what parts need to be replaced
SOURCE: armsrtong 1/12 horse pump noise
I bled air from the rads attached to the system and now the noise is gone from my circulator pump
Posted on Dec 04, 2008
  • 77 Answers
SOURCE: pump humming noise, wont turn
Yes you are correct...impeller is seized.
Posted on May 14, 2009
  • 89 Answers
SOURCE: My water pump is locked and is making a hum noise.
IS IT AN ABOVEGROUND OR SUBMERSIBLE (INGROUND) PUMP. USUALLY THIS IS CAUSED BY A BAD CAPACITOR OR BURNT POINTS ON THE PRESSURE SWITCH. THE CAPACITOR IS EITHER IN A RELAY BOX AT THE WELL OR IN THE MOTOR CASING. HOPE THIS HELPS. JODY
Posted on Jun 29, 2009
  • 151 Answers
SOURCE: my sump pump is making a loud humming sound and is
if the pump is 220v make sure that both fuses in the unit are on. If both fuses/breakers are good and the unit isn't pumping water the unit may have froze up. Remove the power from the unit and try to manually rotate the motor shaft at an attempt to free it up. If that doesn't seem to work the bearings may need to be replaced.
Posted on Jan 17, 2010
Mackmech11
  • 122 Answers
SOURCE: Tsurumi submersible pump with a bad bearing.
Mostly likely no.. These pumps have a sealed bearing that can not be serviced.
Posted on Apr 18, 2010
Well water pump won't stop running
if it is a submersible well pump it could be crack in your line leading to the bottom of your commercial welcome and called it to leak water and still feel pressured
if it is a submersible well pump it could have a crack in the line leading to the summer double well pump in the ground it will cause it to leak but the tank will still be build up pressure
Jan 10, 2015 | Pentair Water 123324 1hp Submersible Well...
It makes a humming sound but does not pump water. the pump gets very hot there is no debre in the outflow
The motor is binding that's the humming noise. Check to see what **** the thing sucked up. Then try to clean it out. I dont know what happened
Dec 25, 2010 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
My pump won't run it just makes a humming noise and gets hot. the impeller spins freely by hand.
If the pump is fairly new it could be the starting capacitor,
But if the pump get really hot quick its the motor who is damage and need to be rebuild or replace,
how old is your pump and wich model do you have?
Aug 13, 2010 | Tsurumi Pump s Submersible Trash Pump -...
Submersible well pump poping breaker
The motor is locked and you cannot reverse it... the pump will need to be pulled and replaced...
Replace it with a "sandhandler" type pump that will pump the grit through it with out hurting it..
heatman101
May 24, 2010 | Flotec 075 HP Submersible Well Pump 3Wire...
I have a jacuzzi 1/2 hp submersible well pump. Does this need any regular maintainance to keep it happy.
No preventative maintenance is necessary. However, a happy pump always has water above it and should not pump sand. If the water level in the well is below the pump/motor they will overheat. If this is a problem your local pump company can install a module to protect your pump from this type of event.
Please rate this answer.
Jul 03, 2009 | Jacuzzi Brothers 1/2 Hp 8gpm 2 Wire...
My water pump is locked and is making a hum noise. What do you recommend doing.
Jun 28, 2009 | AO Smith Plumbing
Little Giant stopped working; makes hum noise but wont push wate
Can you take it out of where it is and clean it with vinegar? There may be calcium built up in it. I have one also on my aquarium and when I turn it off sometimes it won't start back up, just humms.. That tells me it's time to clean it.
Jun 07, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Plumbing Logo
111 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
