Question about KitchenAid Food Mixers
How to repack KFP1355 kitchenaid food processor to return it
read the amnual, what problem you have whit this apliance?
Feb 17, 2015 | KitchenAid Food Mixers
I own the 6 QT Stand mixer. Is there a Is there a 4 or 5 qt bowl that works with this mixer?
Kitchenaid does not make a 4 or 5 quart bowl that would fit your 6 quart mixer, but other 3rd party companies do!
You may be in luck.
I haven't seen this bowl in person, but it apparently will fit your 6qt mixer. Here is a link to a page selling the mentioned attachment. It comes in a set, with appropriate wire-whip attachments:
Jan 13, 2015 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
No power
Check for broken wires around the black speed control assembly under the back cover. Check carbon brushes, THEY ONLY FIT ONE WAY. Check cable for continuity.
Jun 24, 2013 | KitchenAid Food Mixers
Kitchenaid mixer leaking oil
Get a copy of the Repair Part List for your model at
Grease inside the Planetary Assembly (the shaft is tight fit to the Planetary
plate at the factory and is not designed to be taken apart, so do not use
any hard object such as a screwdriver to separate them) over times can
turn to liquid and leak down the bowl. Removing the Planetary assembly
and adding Kitchenaid Food Grade Grease is not a task for a novice.
To properly remove the Planetary Assembly, you must work from inside
the Transmission Housing: Remove in this order: Retaining Clip(25), Bevel Gear(21),
Retaining Pin(18), Worm Follower Gear(19). Use a soft mallet to tap out the Shaft
of the Planetary Assembly(15). Re-assemble it in the reverse order.
Note: The Bevel Gear is extremely tightly fit on the shaft, and a pin punch
must be used to remove from the shaft.
Jul 14, 2011 | KitchenAid KP2671 Professional 6 Series...
Are attachments for a KitchenAid K5 compatible with the K55?
That would be incorrect. If the attachment is for a hobart kitchenaid mixer then it will fit all models of kitchenaid mixers including the brand new pro series because the attachment port and drive gear has not been changes since 1925 or 6 when it was first introduce by the Hobart company.
Apr 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
I can't get the bowl onto my KitchenAid Pro mixer
Hi. I'll give you the cheap/fast solution first. Get a 2-3 ft. section of metal pipe that will fit over the bent arm, gradually, incrementaly and slowly bend the arm out using the pipe. check it at each increment for fit and level.
Now for the more expensive/slow solution. Find the nearest Kitchenaid "approved" repair service store. You will then be looking at a replacement bowl support and the labour to repair it. Be prepared to wait for up to a month for Kitchenaid to fill the parts order. If you find that these solutions have assisted you, please rate them. Good luck! ricardok45
Mar 03, 2009 | KitchenAid KSM50PR Professional Series...
No Problem
This is "middle of the line" Kitchenaid as far as bowl size and motor strength goes. However, it is a great mixer that will probably fit your needs.
Nov 28, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
The beaters don't fit anymore
It depends on how mechanical you are. The old part will probably need to be cut off since it is pressed into the base of the rotating head. Parts are available from many sites like and the like.
Nov 27, 2008 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
48 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
