Nook Model # BMTV250A has stopped responding to touch. Can't open it up. Have cleaned screen and cleaned out bezel sides; still can't open it up after it powers on.
  • 6 Answers
SOURCE: touch screen & key board with stick does not respond
try aligning the screen...
settings > screen > general > Align Screen
If that doesn't work try hard reset... i.e.
press the two soft keys and the reset button using stylus...
If its still not working do soft reset:
settings > system > Clear storage
but remember to take back up of phone before doing this..as it will erase all your data...
and do tell me if it worked or not...
Posted on Jun 25, 2008
  • 103 Answers
SOURCE: nintendo ds touch screen
All 3, your touchscreen is defective and must be replaced. If you can, you can order one at the well known auction site and replace it.
Posted on Nov 28, 2008
nandini789
  • 430 Answers
SOURCE: Just won't power on
This must have encountered rusting or jamming. Service must be called to open monitor frame.
Posted on Aug 15, 2009
SOURCE: Palm Treo Pro touch screen problem
My phone did the same thing.<br />
Posted on Aug 20, 2010
  • 106 Answers
SOURCE: My Garnin Nuvi 760 has
The problem is probably with touchscreen (a thin film on screen)
You can try order a replacement touchscreen on ebay and replace it yourself
Tip: order a couple of them, they are cheap but extremely fragile
Posted on May 19, 2011
My nook is not responding to touch. I cannot get the settings button on and it is talking
Give it a good screen cleaning and take a piece of paper and go around the edges where the screen meets the backing. Sounds ridiculous but it works.
Sep 18, 2017 | Tablets & eReaders
My nook says everything has stopped responding how do i get tothe page to reset to factory settings
There are two methods to reset your nook device:
Just follow the link and reset with these simple steps
Hard Reset Procedure For Nook Users
May 23, 2016 | Barnes & Noble Nook HD
Have downloaded e-books from the library, but can't delete them from my Nook.
For some books, downloaded from your PC, the only way to delete them is to attach the Nook Simple Touch to your PC and open the Nook Simple Touch on the PC. (For a PC, open the computer icon and look for the Nook icon and click on that.) From your PC you can delete files from the Nook Simple Touch or move them off the Nook Simple Touch to your PC.
IF you have a MAC or if my advice doesn't work, you should contact the Nook support. It is at the Nook website. Click on Nook and look for Nook support.
Jul 30, 2015 | Barnes & Noble NOOK Simple Touch eReader -...
How do I unlock my nook when the screen wont respond to touch when you swipe to unlock
Turn off and wipe screen with a damp (not wet) cloth and then wipe with dry cloth!
Dec 28, 2014 | Barnes & Noble Nook Tablet
Touch screen wont work
Simple touch glowlight 2012 model. My touch screen wouldn't work. I had full battery. I couldn't power down using the power down button, I had to force it to shut down. I couldn't slide the unlock nor could I turn pages with screen. I only could turn pages with buttons on side. After much research I found that it just needed a simple cleaning. I used a vacuum to gently suck out dust in the crevice of the screen. Or you can use a canister of air to blow the dust out. Do this at an angle so that you don't blow it deeper into the crevice. Also, Use a cloth misted with H2O (almost dry) to wipe the screen from edge to edge. These screens use sensors that are from the side of the screen.. Debri will block the sensors. Mine works great. Too bad I already purchased another one after I found the solution.
Feb 13, 2014 | Nook HD+
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment.
Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
Nook won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 14, 2012 | Barnes & Noble Nook Simple Touch eBook...
Touch screen not working for pioneer avh-p4300dvd
you have to clean the debris out of the gap on the bottom of the screen
Oct 09, 2012 | Pioneer AVH-P5700DVD Car DVD Player
My screen on the nuvi 660 will not respond.
Please don't attempt to do this yourself. You need the right tools so you don't damage the case and internal parts. Also, a replacement touchscreen does NOT come with the 2mm double-sided adhesive to apply it to the LCD bezel. You have to pry off the old touchscreen & glass, clean off the adhesive residue and apply the new screen. I've done this hundreds of times. Unless you have the right tools, you risk damaging your unit. I've received countless number of units that were damaged by their owners.
Please see this link for more info:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Aug 25, 2009 | Garmin Nuvi 660 GPS Receiver
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
