Question about Cooktops
Replacement glass only cooktop 20 x 10 inch - Cooktops
  • 1,181 Answers
Make and model?
Posted on Dec 13, 2016
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 | GE Cooktops
How do I lift out built-in KitchenAid glass cooktop KECT 365 when mounting brackets wern't used
You are either:
A) missing the mounting screws and brackets that hold the unit in place
B) it is stuck and will require brute force to remove
C) both
Dec 30, 2013 | KitchenAid Cooktops
How to dismount KitchenAid cooktop model KECT 365
Why not refer this issue directly to KitchenAid. Maybe they can explain the disparity between what the installation sheet shows and what you actually don't see.
Hairline crack 10 inches long on electrolux cooktop with 1 inch long "bubble" I did not drop anything on the cooktop
mainly caused when customer uses aluminium on the glass top.
only solution: new glass.
Oct 21, 2013 | Electrolux Cooktops
Glass top is scratched and discolored...can you replace just the glass top? Susan
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
My glass cooktop has cracked across the top left corner. It has created a triangle, about 1-1/4 inch on each side. Is this a flaw in the glass?
most of the time for this to happen something would have had to been dropped or excessive weight on the unit ... it is possible over time the unit had a unseen hairline crack and the heat has caused it to become worse... the glass for these units are ridiculous in cost but can be repaired...
several online sites sell parts.... a few reputable companies are
Jan 21, 2011 | Whirlpool GJC3034 Electric Cooktop
Cracked Glass cooktop
the glass top can be replaced.but u want 2 find out the cost of it first.they are pretty expensive and sometimes run almost equal to the cost of new it to the cost of a new cooktop.
Jul 18, 2009 | Cooktops
Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Apr 18, 2009 | GE 30 in. Profile JP350 Electric Cooktop
The glass can be replaced. Go to any appliance parts website and look up the model number for your cooktop. They should have a parts directory and then search for your cooktop glass. I warn you though - the glass is almost as expensive as a new unit!!
Mar 13, 2009 | Whirlpool GJC3034 Electric Cooktop
Jenn-Aire Cooktop Glass
You can order the replacement glass for about $225 from companies like or
Part Number: AP4095442 made by WHIRLPOOL, black
Part Number: AP4096135 made by WHIRLPOOL, white
Dec 22, 2008 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Cooktops Logo
162 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
