PTH123A35 Error code 1 what does it mean - Office Equipment & Supplies
Ricoh 1813. Error code c551
The Ricoh copier error code SC551 / 551 is a fusing thermistor 1 error code.
It can mean:
1. The thermistor is not connected
2. The thermistor connector is bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
Oct 03, 2017 | Ricoh Office Equipment & Supplies
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
What is error code 1 mean?
Good Morning Friend,
I understand you are receiving an error code "1" on your Electrolux dishwasher. Error code "1" is a leak detector. This does not necessarily mean that there is a leak. This could be a false code. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 20-30 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
Jun 19, 2014 | Electrolux Dishwashers
I have a R 93 ami jukebox and keep haveing error codes 1and4 what do they mean
Error 4 means the memory backup battery inside the Central Control Computer is dead or very low. Error 1 means factory defaults are being loaded due to a dead battery.
Jun 15, 2014 | Wurlitzer Jukebox CD Player
What is error code no. F6E5 mean in Whirlpool Dishwasher (ADP 6776), and how to solve this problem?!
The error code F6E5 means "Cancel key error". Press the "Cancel" and "Start" keys in the following order: CANCEL, CANCEL, START. Verify the error code displayed on the control by observing for longer then 1 minute. If the error persists, the display board has to be replaced.
Sep 27, 2013 | Dishwashers
Check engin light on. There are four error codes P0137,P0141,P0342, and P1792. How do I fix it. Will I pass inspection with these codes?
P0137 Error code Faulty O2 sensor Exhaust leak near the rear sensor
  • Plugged catalyst
  • Short to voltage on O2 signal circuit
  • High resistance or open on O2 signal circuit
Possible Solutions
  • Replace faulty sensor
  • Repair exhaust leak near the rear sensor
  • Check for restriction in catalyst and replace as necessary
  • Repair short, open, or high resistance on o2 signal circuit
P0141 Error code means Downstr Heated Oxygen Sensor Heater circuit fault - Bank No. 1.
- replacement is needed for this issue.
P0342 Error code means Camshaft Position Sensor Circuit Low Input
P1792 Error code means P1792 means the computer isnt properly programmed so if this code keeps comming back the pcm may need to be replaced
Aug 13, 2010 | 2002 Daewoo Lanos
Amana Ac compressor won't come on. Heat works fine. red light blinks once and code is normal. pth123a35
would suggest replacing the compressor capacitor first before going any further. The capacitor aids in the initial start up of the compressor and if it is bad the compressor will not start. The capacitor is located in the area behind the control switches and is usually gray in color and round. They may be oval and silver also. For this type unit I think the capacitor is a dual capacitor which means it also runs the fan. Note that the compressor side of the capacitor can be out and the fan still run. So before I would think about replacing the compressor I would replace the capacitor which is about 30 to 40 U.S.D.
Good luck hope this helped
Mar 30, 2010 | Amana PTH123B35AJ Air Conditioner
CD disk error
ok error code 1, look for this error code on your owners manual, toyota cd players give 3 error codes, this mean error code 1, error code 2, and error code 3, they all have different meaning please check owners manuel to see what does error 1 mean i will try looking for you
May 26, 2009 | 2007 Toyota Camry
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
F 1-4 Error Code
f1 is usually bad oven control board. Look for a tech sheet on the back of the oven. This will tell what all of the codes mean and what to check for.
Sep 24, 2007 | Maytag MER6772 Gemini Electric Kitchen...
27 people viewed this question
