Question about Vacuums
Why is water leaking from bottom of my shampooer
    Top Expert:
  • Vacuums Master
  • 52,091 Answers
Dirty seal ring possibly
Posted on Dec 13, 2016
Water leaking from carpet shampooer
Need to know where it is coming from. Inspect thoroughly to determine source of leaking water
Sep 19, 2017 | Vacuums
My bissell portable stain remover shampooer leaks water from the bottom
Check your Customer Care Guide for the location of the filters. I'm not familiar with this machine but if it has a "Flow Indicator" there's a filter under it. Just screw off the Flow Indicator Cap and you'll find a rotor. Under it is a filter that gets clogged and needs to be cleaned. There's usually a filter on the cap of the water tank as well. It looks like a screen, remove it and clean it too. The back pressure can lead to leaking. If that didn't help call the Bissell Consumer Care at
1-800-237-7691 Hope that Helped.
Feb 15, 2015 | Bissell Vacuums
How do I cycle the valves on the bottom with the eraser end of a pencil on my hoover dual vac shampooer
The center part of the valve (stem) pushes up (spring loaded) to release liquid. If it leaks it can (and should) be replaced. Also, check the black valve seal (conical shaped ring around the outside) for cracks or splits as this can contribute to leaks. The entire valve assembly (similar to photo) should be replaced to solve both issues.
Oct 09, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How to change the belt on my bissell 12amps powerheat shampooer,
the belt is simple there is a door on the side of the machine remove it and you will have easy access to the belt. For the other problem use this repair guide.
http://newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Troubleshooting_ProHeat2X_9400F.pdf
Apr 17, 2009 | Bissell 1699 ProHeat Clear View Upright...
My Kirby shampooer - G4 - hardly used any water from the tank and no suds at all. Pet hair did blow out of the small slotted holes in the tray as I moved the shampooer back and forth, but the carpet was...
Few things:
Make sure the sponge and the valve under the sponge (water tank) is clean.
Make sure you follow the instructions (f you do not have the manual you can find one HERE)
See if the straw inside the water tank is not clogged (happens when you use toilet tissue or some other paper to dry inside of the tank after you shampoo)
Noise - if it is noisy al the time - it may need new shampooer brush roll. Also check the tray - bar brush roll bearings overheat and melt the tray... Never submerse brush roll in water when cleaning it. Clean it simply by lifting the shampooer nozzle and letting it spin for 10-20 seconds. If you have tu put it under running water - put it back in the shampooer nozzle (with tray and shield) put on Kirby and turn it on for 20 seconds or so. If it stays soaken wet - moisture damages barings.
Good luck
Feb 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Shampooer dispensing
I occasionally run some water and vinegar (equal parts) through the machine, just as I do for clogged holes in my steam iron. So far it has been doing the job.
Nov 03, 2007 | Dirt Devil CE6000 Featherlite Wet/Dry...
Cleaning Solution leaks out around bottom
Most likely the opening under the seal has cracked or is starting to break away. You will have to replace the water bucket, the soap dispenser come with it, not separately.
Oct 20, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Kirby shampooer
You are missing the wee round suds screen that fits over the small hole on the tank where the hose fits on. Without this screen it will not make foam.
Oct 07, 2007 | Kirby Heritage II Vacuum
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
