Question about Vacuums
I bought shoes and bag set but need bigger shoes but bags fine do i just return the shoes or do i have to send both back and reorder
    Top Expert:
  • Vacuums Master
  • 8,248 Answers
That you will have to take up with whoever you bought them off.fixya can not help you with this.
Posted on Dec 13, 2016
I ordered vacumn cleaner bags. Wrong size. How do I send them back I asked for ups to pick up at my house no one has come
firstly you need to contact the seller for return authorization . when they send that they may tell you how to return them
Dec 08, 2016 | Vacuums
My electrolux ambassador stopped working suddenly
This may be a bit late, but if you're using an afterfilter on your vacuum, check it. These should be changed every sixth bag or so. If not, it will get extremely dirty and block the airflow, causing the motor to overheat and shut off.
There could be other problems, but this is the easiest thing to check, and the quickest fix. You don't really need the afterfilter to continue using the vacuum. It's there to prevent fine dust particles that have gotten through the bag from returning to the home. With the new bags out now, it's kind of obsolete, but HEPA afterfilters are made for newer Aerus Electrolux vacuums for folks concerned with fine pollens and dust, and those with allergies.
If you've ever had a bag break, then dirt has also gotten into the motor. This will cause problems, and the motor should be cleaned as soon as possible. The wiring can be checked while this is done, as a loose wire can also cause this problem.
Mar 15, 2014 | Electrolux Vacuums
While vacuuming the red light for the bag of the vacuum came on and the vacuum stopped. The bag was no where near full so I replaced it with a new bag - same problem. It vaccumes for a minute or then stops...
I'm assuming this is the Epic 6500 or similar model.
Detach the hose, turn vacuum on. If it runs, place palm of hand against inport hole. If it shuts off the problem is with either the control valve setting or the control valve assembly itself.
For cvs, turn dial on top of vacuum all the way to the largest dot, and try above test again. If that doesn't work, then it's the CVA. It needs to be cleaned or replaced, which is an in shop job. Fro repair, take it to the nearest Aerus Electrolux store. I recommend a full clean and service to remove any dust/dirt from the motor, fan assembly, and other internal parts.
Another problem, which relates to the dial setting, is that fine dust will quickly clog the pores of the bag, resulting in the machine "thinking" the bag is full. Turning the dial to the proper setting helps get the bag fuller. The middle setting is the normal setting, and is for areas without fine dust and sand.
Dec 05, 2010 | Electrolux Vacuums
Full bag light will not shut off, even after replacing with a new bag and that includes the other filter on the back. I have a lux legacy vacuum cleaner and its less than a year old. Is ther some kind of...
First, make sure the dial on top of the machine is set at the half way point. If it is, and there's a lot of fine dust in your area, try turning the dial so the large dot aligns with the arrow.
If it's less than a year old, actually less than 10, the warranty is still in effect (unless generic bags are being used). The best thing to do is call the store or consultant you bought it from and talk to them. They can pick it up, or you can take it to the Aerus Electrolux store for repair. They will also gladly answer any questions you may have about the product. It's a great machine, and investment, and needs proper care to get the most out of it.
Make sure you take your "sales agreement" with you.
There are things that will void the warranty. Using commecially, vacuuming liquids, using generic "made to fit" bags (genuine bags have "Home Solutions" printed on the top), buying on-line (E-Bay). Check your manual for others.
To find an authorized dealer near you, go to http://www.aerushome.com/storelocator/, type in your zip code, and click on "view dealer list".
Oct 06, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
Using my miele 4211 without a bag
You did what??? That really is asking for trouble! If it cut out from overheating then yes, it will come back to life when it has cooled. If it doesn't recover, you'll need professional help. I've no idea what country you're in, but in the UK Miele offer a fixed-rate repair service including collection and return delivery and new filters and a bag (!), which will almost certainly be cheaper than getting an independent service centre to do the job.
May 25, 2010 | Miele S 4210 Bagged Canister Vacuum
I broke the zipper on the cloth bag on my kirby gen. 3 can i replace this myself
Yes.
To order Kirby vacuum bags, replacement parts, or cleaning products, please visit your local independent Kirby Distributor, or call:”
1-800-437-7170 United States and Canada
Nov 15, 2009 | Kirby Generation 3 Bagged Upright Vacuum
When turned on the sound is like its screaming. It appears to be coming from the filter compartment. It all seems to work ok.Thanks
I suggest checking the filter. If it's coming from the HEPA filter area, the filter might be out of position or possibly you have the wrong kind of filter. Miele uses 2 different types of HEPA filter so that could be the problem.
Aug 23, 2009 | Miele Cat Dog Plus S511 Bagged Canister...
No hose suction with replacement bag
The Bag must be blocking the port it connects to. Remove the bag and close it up. Test it again with no bag in it. If you have suction now, the bag is blocking the port. Maybe it is the wrong type, or installed wrong.
Feb 24, 2008 | Kenmore 28075 Bagged Canister Vacuum
Vacuum shooting out dust
i dont know what kinda vacuum u have u didnt specify so try changing bag,dump cannister clean filters or just cuss it out lol
maybe one of these will help
Dec 28, 2007 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
