Question about Rheem 13PJL24A01 2 Ton 13 SEER Heat Pump Air Conditioner
Addendum to earlier post. Wiring diagram inside cover of unit is illedgible. It is a Rheem condensing heat pump built in 97. I believe it is a Mod. RRKA A030J. Model and S/N tag damaged.
Fan won't start without a push. Also need parte list.
    Top Expert:
  • Rheem Master
  • 8,163 Answers
Bad start up capacitor
Posted on Sep 16, 2017
5 Suggested Answers
mrgrzz
  • 88 Answers
SOURCE: condenser fan wont come on nor will compressor I do have fan op
Thanks for your Question,
First thing to check is the breaker in the panel to see if its tripped, I would suggest turning to off, then back to on, if it trips right after you have a short, if not you will need to check your fuses at the disconnect, first, shut the breaker off to the condensor, then pull the fuses and Ohm check them, if you have no reading then one or both is bad, I would recommend replacing them both if thats the case, if they check good, then you have bigger issues with your heat pump, if these suggestions do not work let me know and I can go into more indepth proceedures with you on what to do, thanks again,
mr.grzz
Posted on Jan 25, 2009
  • 119 Answers
SOURCE: Need to relight Rheem hwh.
electric heaters dont need to be light because they dont use gas, the power is off to the heater or the thermastat is bad or the heating element is bad. call the manufacture and get free customer service and support over the phone.
Posted on Apr 27, 2010
SOURCE: I have a Rheem Heat
What filter are you talking about?
Air filter: Usually with a heat and air unit, the air filter is located behind the return air grill.
Return air grill looks similar to ordinary ceiling or floor grill where the hot or cold air blows into each room. Except the return air grill is larger and is usually put close to the heat-air unit.
Remove the grill and replace filter every 3-6 months.
If no filter is present, then dust and hair get stuck on the coils and unit will not meet temperature setting.
See image of typical air filter:
http://www.instablogsimages.com/images/2009/02/12/air-filter_IYR3W_69.jpg
Posted on Jul 30, 2011
Fixitman909
  • 430 Answers
SOURCE: I have a problem with a Rheem Power Vent Water Heater shutting down due to condensation build up.
if it,s condensation....let it sit out side in sun to dry out well then bring it in start it and with a flash light look for leaks
Posted on Aug 13, 2016
I need the low voltage wiring diagram for this condenser model 10pjb24a01 weather king
That 10 seer heat pump is typically wired.
http://rheemote.net/docstore/webdocs/Public/ServicePublic/Trouble2/pdfs/Wiring/90-21779-08-06_HP_Typical.pdf
These were typically installed as the cheapest thing available to a homebuilder, mainly installed in rentals and affordable housing. Naturally, they cost the most to run. A higher efficiency unit will pay for itself in a couple of years and then save money every time it runs after that. Of course, replacement parts are inexpensive, so this is ideal for a rental property.
Jan 12, 2015 | Protech Rheem Ruud Weatherking Factory OEM...
Wiring diagram for Rheem rpka-31 jaz heatpump
TURN THE POWER OFF TO THE UNIT. TAKE THE BACK PANEL OF OF THE HEAT PUMP AND LOOK FOR A SQUARE PLASTIC BAG FASTENED TO THE INSIDE OF THE UNIT, IT MAY BE LOCATED BY THE CONTACTS AND SYSTEM WIRING OR ON THE PANEL ITSELF. REMOVE THE PAPER FROM THE PLASTIC AND THIS SHOULD CONTAIN YOUR WIRING DIAGRAM. ALSO LOOK ON THE BACK OF THE PANEL ITSELF FOR THE DIAGRAM. SOMETIMES THE DIGRAM IS PRINTED THERE.
Apr 13, 2010 | Heating & Cooling
Hello i want to conect a trane condensator 2twb0036a1000ba to a trane evaporator mww536k10raa i need a wiring diagram
Your wiring concerns may be more with the thermostat wiring connections than the condensor connections. if you look inside the cover of the evaporator unit (usually called air handler) there should be a wiring diagram glued to the panel cover. This diagram will show all 3 units (stat,cndsr, airhndlr) and the wiring needed between them. Trane and Lennox are notorious for having the most wiring between components. You also need to be sure the stat is the correct type for the system (i assume this is a heat pump system) and there can be as many as 9 wires from stat to system and 6 wires from inside to outside units. Also, the stat will have a wiring diagram with it that shows most typical system wiring including the wiring between in and out units. Your best bet (if you have no diagram on the unit or with the stat) is to call trane and have their tech division fax a diagram to you. Goodluck,Macgivor
Jan 27, 2010 | Heating & Cooling
Installation manual required for teco split aircondtioner. Reverse cycle LS0909Y. I have operation manual but not sure how to install and wire up. Many thanks.
Is the unit an AC only or a heat pump?
Wiring to the units should in the manual or online.
Both units proper house voltage to inside unit and outside unit.There will also be a two wire low voltage cable between thr two.This is so the inside unit can turn on the higher current draw of the compressor in the outside condenser unit thru it's relay.If you have a heat pump there will also be a set of two wires to the 4 way gas valve in the condenser unit to change from heating to cooling mode,a set of two wires to control the on/off function of the fan in the condenser unit when it needs to defrost and mayby a two wire set to a themal sensor in the condenser to sense if it is frosting up when system is in heat mode.
Try to get a wiring diagram and if you can't get to the point where you understand how to wire the unit don't guess! Call someone who knows wiring or call a pro, he can you money over the cost of replacing parts if unit is miswired.
Oct 06, 2009 | Heating & Cooling
Replace Contactor Relay on Rheem Air Condenser
I have a Rheem heat pump/airconditioner, Mod # RPFA-036JAS, that I have had problems with for at least 5 years and have paid over $1,000 in parts and service calls. I can vever recreate the problem when a tech is here. It usually happens in the middle of the night. I hear a Click, ckick, click sound, through the unit and it sounds like it is comming out of my air handler, but the outside unit also clicks at the contactor and the condensor cooling fan moter will start and stop about every half secongd or second. Both contactors have been replaced, the small one twice, one capaciter
has been replaced. I allow the unit too cool down and its alright for a few hours. That is difficult when the outside temp is below zero. HELP PLEASE!
Feb 16, 2009 | Heating & Cooling
Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
Rheem 13PJL24A01 2 Ton 13 SEER Heat Pump Air Conditioner Logo
52 people viewed this question
Top Rheem Heating & Cooling Experts
jeff5may32
billconfused
Lawrence Oravetz
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
