Question about GPS
Weatherproof Garmin GPSmap 478 has moisture on the inside of the window. Works fine. How do I remove the moisture?
  • 630 Answers
Put it in a warm place for a few days. The IP rating allows immersion up to 1m so it should be OK if it's still working. I wouldn't take it apart as if you don't remake the seals properly you'll be stuffed.
Posted on Jul 20, 2009
It is natural for marine electronic units to be exposed to excessive moisture on a boat. There are rare cases where somemoisture may appear inside the screen in the form of a light coat of fogging when excessive ambient pressure and humidity are present in the surrounding air. This means there is air present between the LCD screen of your unit and the outer protective lens. This is attributed to the unit being exposed to drastic humidity and temperature changes which is not uncommon. Temperatures can vary 12 to 25 degrees Fahrenheit between day and night.
The unit is outfitted with a Hydrophobic patch that allows moisture vapors to leave the unit once the unit is exposed to sunlight or as the screen warms up. To mitigate the effects of this process, it is helpful to store the unit in a warmer location such as a house or a garage when not in use.
Last modified on: 12/10/2008
Posted on Jul 21, 2009
  • chebard Jul 24, 2009
    After all was said and done, I placed the GArmin 478 GPSmap GPS in the basement next to the dehumidfier. In 24 hours all the moister and bubbles in the unit disapeared. This was the easiest solution ever.
Compass will not caibrate
Garmin GPSMAP 62 - Initial Setup - Calibrate Compass ...
? 7:27
https://www.youtube.com/watch?v=OG7uVh2kQ24
Nov 9, 2010 - Uploaded by Jim Cyr
have owend 3 garmins. will be using handheld for biking. this looks like fast map ... Anyways, your review was decent, just don't know if I like garmin (possibly not). .... Compare Garmin GPSMap 62S vs Garmin GPSMap 60Csx ...
How to Reset the Garmin GPSMap 62 Series Handheld ...
? 1:23
https://www.youtube.com/watch?v=v-M7Ev6YTcA
Jul 20, 2012 - Uploaded by GPSCity
GPS City will show you how to RESET your Garmin 62 series GPS back to factory default settings. Back up all ... -My GPSMap 62s will not track satellites! -Forgot what ... -My barometric altimeter will not work or calibrate.
[PDF]GPSMAP® 62 series - Garmin
static.garmin.com/pumac/GPSMAP62_QSM_EN.pdf
Jan 04, 2016 | Garmin Gpsmap62s Hand Held Gps
Tip
How to Download your Garmin GPSMAP 545 / 545s Users Guide
Have you lost your User's Manual for your Garmin GPSMAP 545 or 545s?
Would you like a digital copy for easy searching of terms and quick reference?
The GPSMAP 545 owner's manual is available from Garmin here.
I hope that helps.
on Jan 31, 2010 | Garmin GPSMAP 545s GPS Receiver
My gpsmap 4012 shows the maps blurry as if it takes too long to load.. any ideas
Do you have them saved to the gps or to the memory card? I had to get a bigger memory card and saved them to it when I updated my maps last time.....
Jul 17, 2014 | Garmin GPSMAP 478 GPS Receiver
My Garmin GPSMAP 178C screen backlight failed
Backlight problem: Remove the display, remove the light tube from behind the LCD. Buy a led panel from Ebay for around $5 and install it behind the LCD under the drfusing layers. Run the wires out to a 12 VDC source and there you have it.
Jul 13, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
The GPSmap 176c does not turn on. I have put in new batteries and cleaned the metal parts of the battery receptors
Do you use rechargeable batteries? The 176C seems to be extremely picky about the voltage. I had the same problem. Afer changing to non-rechargeable batteries, everything works fine again. Not great for the environment, but for my bearings.
Jul 12, 2009 | Garmin GPSMAP 176C GPS Receiver
Garmin gps 498.
I have the same exact problem, but i don't have a solution
Mar 24, 2009 | Garmin GPSMAP 498 Fishfinder /...
Garmin GPSMap 60 CSx USB Connection
Actually, I just solved the problem myself...
I went to Garmin's driver download site (http://www8.garmin.com/support/download_details.jsp?id=591) and got the latest USB driver (2.2.1) for the 60C. (Although, it appears that that driver pertains to all Garmin products, not just the GPSmap series or the 60C.) Installation instructions are pretty much standard for Windows drivers, so it's easy.
That: a) Garmin requires special USB drivers for their product is finicky (most USB-connectable products just connect automatically using Windows' generic USB driver), and b) my unit -- which had always worked just fine, and suddenly stopped connecting out of the blue -- remains a mystery. Nonetheless, a driver upgrade was the final step that I needed. (Although, I also swapped USB cables and upgraded MapSource, too, so maybe it's some combination of those things.)
Dec 15, 2007 | Garmin GPSMAP 60CS GPS Receiver
Garmin GPSMAP 60Cx Powerup Problem
I suddenly had the same problem. Here a page with the explanations : http://forums.motionbased.com/smf/index.php?topic=3814.0 I removed the cache back to clean power connectors, tighten the cache back to properly adjust the power connectors on the map. Now everything is working properly.
Oct 31, 2007 | Garmin GPSMAP 60Cx GPS Receiver
GPS Logo
120 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
