Question about Hisense Televison & Video
Hisense 48h5 no picture on TV when I take a flashlight to TV I see an image I've replaced power supply board
  • 113 Answers
SOURCE: I have a samsung 26
hi,
your lcd ip board (power board) capacitor had already exhusted.
got to replace the ip board. even if the caps look fine you would not know if the transformer coil is working ;)
Posted on May 10, 2010
budmrtn
  • 11361 Answers
SOURCE: Vizio SV470XVT1A has no backlight
The 24vdc is turn on by the signal from the main logic board, it is not always on, the standby 5vdc is always on. So yes it can be the power supply board is bad, but just to besure we need to find out if it is getting the turn on signal from the main board first.
You can have 24vdc at the inverter board and it will not light up the CCFL until it gets the signal from the main logic board to turn the lamps on (this is the STANDBY condition, the TV is on but the screen in not lit up util it see the video signal).
Send me good clean and clear pictures of the power supply board, budmrtn@aol.com, connectors of the Power supply, bottom side of the board, then I may be able to tell you which pin is a control input pin. Most people will just throwing parts in and hope that they one of the parts will fix the problem. Used Power supply module for this TV is over $100. http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=delta+DPS-379AP&um=1&ie=UTF-8&ei=USsxTKn3J6TonQfFlJGEBA&sa=X&oi=product_result_group&ct=title&resnum=4&ved=0CCsQrQQwAw
http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+SV470XVT+
Posted on Jul 05, 2010
Testimonial: "Bud helped me fix my TV! It was only 1 1/2 years old. I was looking at a repair bill close to $300 - $500 and I fixed it with a $60 board! Thanks!!!"
  • 517 Answers
SOURCE: I have a olevia model 232-s12 tv has sound but no
Good day.
If you already replaced a new inverter board and T-con board and the problem is still there.Try to play the video on the DVD,if the video is OK check the cable connection and try to run auto scan.
If the problem is still there check the input supply of the system board or main board it should have 5vdc and 12vdc,if it is OK replace the system board.
Review this manual page 4-1 abnormal display http://www.scribd.com/doc/36875894/Olevia-232-S12-SM
I hope this solution will be helpful.Thank you for using FixYa.
Posted on Apr 17, 2011
SOURCE: I have a Sceptre X32-HD.
The lcd tape under the metal frame the screen side may be bad put something between there to increase pressure on the tape connection to the lcd.
Posted on Jan 21, 2012
gopakumarg43
  • 75289 Answers
SOURCE: lg led tv backlight
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Feb 05, 2015
How do i do factory reset on hisense tv ive gotsound but no picture i tried a hard reset i cant watch movies either
Should have worked after the hard reset. Your problem could be with the leds or the inverter board. Do the flashlight test.
May 06, 2017 | Hisense Televison & Video
Hisense 50k22dg should i replace led strips first or power board
I would inspect the power board for mushroomed caps and brunt traces. A edge lit led screen has two ribbon cables coming from the power supply, I would unplug one at a time to see if one side lights up. Both led strips rarely go bad at the small time. The problem is most likely in the power supply.
May 02, 2017 | Hisense Televison & Video
Sound and no picture on a hisense 50 in. tv model no. 50H5G
Yes but to replace all those PCB's will cost the same as a new TV in most cases. and what if it doesn't fix it or the problem is elsewhere.
Oct 31, 2016 | Hisense Televison & Video
My Hisense 50H5G LED TV has sound but no picture. I did the flashlight test and saw an image. Does this mean the Tcon board is bad?
No it means you have no picture, you must do the testing to decide if the PCB is defective or not.
Oct 27, 2016 | Hisense Televison & Video
I have a Hisense 50h5g 50" tv, I have sound but a black screen it passed the flashlight test so I do have a picture just no backlight Iv replaced the power, tcon, and main boards, still have same prob
If the back light is CCFl type; check and replace all CCFL lamps and back light inverter board.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sep 15, 2016 | Hisense Televison & Video
I have a Hisense LTDN52V77US tv. The screen is blank. I don't see a Tcom or a backlight inverter . Do I just replace the main board. I have audio and can see a picture with the flashlight test.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Aug 25, 2016 | Hisense Televison & Video
On my Hisense 50K23DG LED TV, I have sound but no picture.
LCD & LED TV Repair - No Image & Blank Black ... - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen CLICK HERE to BUY ... I have an LG ...
Hisense 50K360G has audio no video will not turn on logo ...
? 1:48
https://www.youtube.com/watch?v=xI3MpZukKm0
Nov 20, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http://bit.ly/ShopJimmy6 Want to ...
All comments on LCD & LED TV Repair - No Image & Blank ...
https://www.youtube.com/all_comments?v=xUzCLgoSPGM
I have sound and picture but no backlight. .... how do you replace the back lighting on a led lg tv? ... I have a 42 inch LED LCD combo DVD TV made by RCA.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - Hi, I have an RCA 32" LED 1080p TV that is less than 2 years old, and it has already lost the video. I can hear sound, and I can see lights in the ...
53 HISENSE complaints and reviews @ Pixxed Consumer
hisense.pissedconsumer.com/
Jan 13, 2016 | Hisense Refurbished 50"" 1080p LED-LCD...
Jimmy shop.ccom has T-con board part #T500HVD0.0 500t10-C02 at the bottom in the description it list model PLDED5030A CRk my model is PLDED5066A-E since the parts # the same will it work in my tv?
If you see an image with a flashlight the T con board and power supply board are good. The back light controller board is the culprit.
Dec 18, 2015 | Televison & Video
I have a Hisense tv model-32k20dw. I can hear sounds from it and when I did the flashlight test I could see the picture. Already replaced pwr supply. What else could be wrong? Can I fix it?
http://electronicshelponline.blogspot.com/.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Jul 26, 2015 | Hisense Televison & Video
Televison & Video Logo
120 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
