Question about AudioBahn Car Audio & Video
How do i replace capacitor of unknown value on amplifier circuit board? Audiobahn A8000T. Component location number is CP10
    Habit-Forming:
  • 28 Answers
First, what type capacitor is it? If it looks like a small can, then this will be a polarized canister type. There should be a small band on one side with arrows and probable plus marks. The wire below the can on this side will be the positive side of the cap. Make sure you note where and how you remove it from the circuit as a new one will have to go back in the same order. Look on the side of the can, you should see a number followed with a figure that looks like a 'u' with a line on both sides. This will mean microfared. Which is a unit of measure. (Example. 1000 u ) would mean one thousand microfared. (Micro is a measure for parts of a million). Now note the physical size. Very important since this determines the power handling capability. Do not reinstall a new part that is different. Now you are on your way to a complete repair. Take the old part and try to find a local electronic parts store. You can usually buy an entire pack of these for a few bucks. You can also search online. You may also use a cap of the same type from an old circuit board if one is available. NOW IF THE CAP IS A SMALL CERRAMIC TYPE, this one will look like a small round disk, usually light brown in color. This one can be reinstalled in either direction. It is not polarized. There should be a number on one side, (example: 1000 u) .the size also matters just like the can type. Replace with identical type. If no number is present, take the part to your local electronics store. (Radio Shack for example). If this fails, I would go on line and find the manufacture of the product. You may also search REPAIRCLINIC.COM they carry a large line of parts. Hope this helps.
Posted on Dec 13, 2016
  • Shane Powell
    Shane Powell Dec 15, 2016
    @RANDY P. The capacitor was blown to peices. No volts or uF are reconizable. I tried the manufacture. No helpful info. The amp is A8000T AUDIOBAHN.
  • RANDY POWERS Dec 16, 2016
    In this case you most likely have other damage. I would try to replace the circuit board. Go to REPAIRCLINIC.COM with the model name and number. The circuit board should have a number as well. You may find a replacement board at a reasonable price there. Hope this helps. Evidently someone ran a lot of power thru your unit to blow a cap like that.
  • 231 Answers
SOURCE: P4004 - Blown Components
if burned components are on output stage or amplifier section on board..Then look at the oposite side of amp..Both amplifier section should be a mirror image oof componentc from other..that way you can know the values of parts.If they are on power supply section ..Then you might need manual if available..
Posted on Dec 24, 2007
StuartB
  • 807 Answers
SOURCE: Car amplifier parts repair question
Does'nt matter what brand, and you seem to know about keeping the correct values etc. What I would look for are Audio grade caps.
If it's a powerful system I usually put higher values in rather than the stated values on the caps, providing the physical size is correct.
Don't know if you still have the user manual but it's here if you want it.
http://www.retrevo.com/s/Adcom-GFA-4404-Car-Amplifiers-review-manual/id/582bh550/t/1-2/
Posted on Mar 17, 2008
zapco
  • 30 Answers
SOURCE: ALPINE MRV F400 AMPLIFIER
your best would be to contact alpine for that info on there website...that is a old amp .
Posted on Jun 23, 2008
  • 631 Answers
SOURCE: CAR AMPLIFIER - GTO 4000 (600 W)
These are resistors.
I don't have the schematic but if there is an R361, it may be the same as the other Rx61 components.
Mouser and Digikey are good sources if you're in the US.
If you send me a good quality photo of the internals of the amp, I may be able to provide more information.
babin_perry@yahoo.com
Posted on Oct 19, 2008
blueextc3221
  • 15935 Answers
SOURCE: i have an audiobahn A8000t amp with the protection light on
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure.
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals.
Note:
I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit.
Posted on Dec 30, 2008
Redlight keeps coming on
well you could be having several issues but it will most likely be one of two of these issues. there could be a cross or a loop in your setup, or you could have and over heating problem. do you have a capacitor hooked in to your system?
Nov 21, 2010 | AudioBahn A8000T Car Audio Amplifier
Burned up
You can try opening it up check the circuit board and see what capacitor burned up or other resistors, transistors got burned and go to Radio Shack and solder the new one to replace the burned one. Or if you still have the reciept return it to the manufactorer and hope it has a 1 year Extended service protection on it so they can replace it.
Apr 06, 2010 | AudioBahn A8000T Car Audio Amplifier
AMP.... question
12vDC
CFM is negotiable - as the higher RPMs the more air it moves. (also louder).
Audiobahn is out of business - and unless someone is willing to tear theirs apart for your info - get whatever they have in stock :)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | AudioBahn A8000T Car Audio Amplifier
Where can I find a cooling fan for a Audiobahn a8000t amp?
Hello fornda,
The fan looks very similar to a 3" muffin fan. The fans from most computer cases would probably fit. You may have to modify how it mounts, and perhaps the connector, but the voltage is the same.
Here's an online retailer. I'd look for the highest CFM at the lowest fan speed to keep the noise down.
Hope this helps.
Aug 07, 2009 | AudioBahn A8000T Car Audio Amplifier
I'm working on an audiobahn A2300HCT and it seems to have a dead short in the front end of the power supply (The fets,caps and rectifiers will all have to be pulled, one at a time.Any suggestions?
Hello rick27,
I'm assuming that you have already pulled the board out and cannot visually locate any out of place looking component and that you've inspected the board for solder bridges, broken pieces of wire, and other signs of FOD.
If this is the board you are looking to troubleshoot, I'd start nearest the fuses and work systematically from there. You can test many components if you just remove one lead from the circuit. Both diodes and capacitors can be field-checked quickly with one lead disconnected.
Jul 16, 2009 | AudioBahn A2300HCT Car Audio Amplifier
Amp keeps cutting off
Do you have heavy enough gauge wire supplying B+ to amp.Big amps draw a lot of current and require very heavy gauge wire. The longer the run the heavier the gauge needed.
Apr 20, 2009 | AudioBahn A8000T Car Audio Amplifier
Audiobahn A8000T has power but is not hitting
Check your cap, it prob went bad. That could be restricting the power flow now. Try it with out the cap. that just might be the prob.
Jan 15, 2009 | AudioBahn A8000T Car Audio Amplifier
Audiobahn a8000t problem
If the protect LED is lit, the amp probably has shortedoutput transistors. To eliminate other possible causes, read throughthe following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 23, 2008 | AudioBahn A8000T Car Audio Amplifier
Protection mode
Driver ICs or transistors,op-amps that create the idle bias circuit,the protection circuit, the power supply. You should have a schematic of this unit and know how to check the solid state devices for shorts. GOOD lUCK
Jul 31, 2006 | AudioBahn A8000T Car Audio Amplifier
Car Audio & Video Logo
61 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
